Alternate alternator
SD Bugeye
I'm looking for a small form inexpensive single wire alternator
would like to find something that isn't half the size of a A series engine and not cost the same as half a engine. Any suspects?
number6
I am not quite sure what your asking for. A small single line alternator half the size of a A series alternator?
I seem to remember you could find something like that on an outboard motor.
nomad
Almost any alternator that you can mount up reasonably will work. Frank C [spritenut] liked one off a Mazda pickup from around 1990 if I remember correctly. I'm running one off a Festiva on my Datsun engined Midget. They are 2 wire alternators but you really need that for your charge light IMHO.
I'm with you...I really like the small skeleton framed alternators. Wandering around a pick and pull with a tape measure might be time well spent. Also a visit to a friendly auto parts store might get you a cooperative helper on the right day.
Kurt.
JPSmit
I have a memory that you can get one of a John Deere Gator (is that what they are called?) or some such vehicle - and I think there was one that came off an isuzu?
SD Bugeye
SD Bugeye
I did some more hunting last night and I found a couple that seem like they may work out now I need to look at the lug location and off set
the one I have now is the ac delco that every GM growing up had . It works perfect and looks ridiculous.
During a few beers the other night while putting a tender on the mustang a buddy of mine looked under the hood of the Sprite and yells out OMG is this the 60's version of a hybrid! Funny Todd real funny
Thanks guys I'll do some checking
SD Bugeye Alternate alternator Spridgets 20
texas_bugeye Alternate Alternator Spridgets 3
Dadandson Alternate Alternator? Spridgets 12
kodanja An Alternate Alternator? Triumph 88
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
Popeye General TR FS2758 alternate - Door Pull Assembly Triumph 2
RAC68 Alternate Trans/OD Oil Selection Austin Healey 17
T Front Flip Hood Alternate Latching Spridgets 12
SherpaPilot TR6 Alternate Door Jam Light Switch Triumph 4
aeronca65t Alternate Detroit Auto Show Other Cars 5
Jim_Gruber VIN number alternate locations - Somewhere by front suspension????? Spridgets 20
H alternate to plating? Austin Healey 7
blueosprey90 MGA An Alternate Sway Bar Link for the MGA with MGB Sway Bar [ a repost] MG 1
tomshobby Alternate routes for the 50th in Wisconsin Spridgets 2
T Weather and Transportation - alternate thinking? Spridgets 43
boeingpilot TR4/4A Alternate differential for TR4A Triumph 4
bill_powell Alternate Seats [again] Spridgets 17
Nunyas Alternate "basic" transportation... Other Cars 29
Ed_K Alternate way to cure fiberglass resin ? Austin Healey 14
F Alternate Seats? Spridgets 17
norcalnewb Alternate Sprite Interior Colors Spridgets 7
S Wedge Alternate/After Market Wheels for TR7 Triumph 6
T TR6 Alternator wiring Triumph 3
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
E MGB external alternator regulator MG 2
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Overtightening the alternator belt? Triumph 14
B TR6 Swapped Lucas to GM alternator Triumph 9
M TR6 Alternator Issue for 72 TR6 Triumph 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
G Spitfire Alternator troubles Triumph 2
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
TheRealDestrux MGB Unknown connector on alternator MG 6
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
AUSMHLY Generator to Alternator Swap Austin Healey 20
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
Lin Fan belt for 1275 with alternator Spridgets 4
