Adjusting Rer Brake of BN6
BN6_2197
Gents,
I read the instructions of the workshop manual (Section M) for adjustinge the rear brakes. Is it corret that I have to remove the brake drums to get access to the adjuster (#11 of the attached picture). If this is true how to adjust them "hard"? When adjusting the front brakes I can use my ears for adjustment since brake drums do not have to be removed.
Regards,
Volker
red57
Hi Volker,
No, you do not have to remove the drum. The adjuster #11 has a small, 1/4" or 5/16" I think, square extending out thru the backplate. You can just make out the square on the bottom (in the orientation of the picture you attached). On you car, look at the outside of the backplate opposite the wheel cylinder and you will see a small square.
Dave
BN6_2197
BN6_2197
Dave, you are totally right. I just misinterpreted the workshop manual. Thank you very much for your quick response. Volker
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
AUSMHLY Adjusting Valve Clearance Austin Healey 31
S Testing and Adjusting procedure for RB340 Austin Healey 4
doc50 Adjusting play on steering box? Other British Cars 5
T Adjusting windows/tops etc. for comfortable highway travel Austin Healey 10
BN6_2197 Rookie question on adjusting valve clearance Austin Healey 9
Jim_Gruber Adjusting Spridget Doors Spridgets 4
Tinkerman TR2/3/3A TR3 A 1960 adjusting apron Triumph 4
drooartz General MG Alternator link - adjusting bracket length on MGB? MG 8
Joe Reed MGB Adjusting the reverse lamp switch... MG 3
vette Adjusting HD8 Carbs Austin Healey 21
M Adjusting Front Suspension Austin Healey 11
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
Geo Hahn TR2/3/3A Steering Box Adjusting Screw Triumph 12
RJS TR4/4A Setting up Self Adjusting Slave Cylinder Triumph 6
Jim_Gruber Adjusting Pushrods in Pedal Box Spridgets 5
B Adjusting SU-HD6 Carbs Austin Healey 2
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
S TR2/3/3A little adjusting screw tr3 Triumph 1
F Adjusting gear lever, centershift 3000 Austin Healey 2
L Adjusting the bows before top installation Austin Healey 2
bighealeysource Adjusting toe in on a Healey Austin Healey 8
M Adjusting TR3 regulator Restoration & Tools 1
Scotsman Adjusting clutch pedal travel Triumph 2
R Adjusting Valve Clearances Triumph 13
Moseso TR2/3/3A Adjusting Koni shocks [TR3] Triumph 10
N Adjusting headlights on a BJ8 Austin Healey 2
A Adjusting BJ8 Doors Austin Healey 5
K TR2/3/3A TR3 Fuel Gauge Again.....Adjusting? Triumph 11
B TR2/3/3A 57 TR3 BONNET ADJUSTING SHIMS Triumph 4
drambuie Adjusting steering box with shims Austin Healey 6
brgrmyster TR6 Adjusting TR6 Headlights Triumph 8
M Adjusting idle speed Triumph 28
bighealeysource adjusting the handbrake on BN6 Austin Healey 1
TR6oldtimer Adjusting rockers Triumph 7
Darwin Adjusting steering play? Triumph 7
hondo402000 TR6 adjusting windows to Wind screen TR6 Triumph 2
T Adjusting valves makes me more crazy. Triumph 18
wangdango 100m bonnet fitting/adjusting?? Austin Healey 4
JohnnyMead Tips on Adjusting the Clutch Slave Pushrod? Triumph 4
pjsmetana Low Idle, DVG adjusting = no dice Triumph 12
pjsmetana Adjusting the Bonnet and the Bumper Triumph 5
DarwinT Adjusting a Weber carb Spridgets 3
bighealeysource ADJUSTING THE HAND BRAKE ON A BN1 Austin Healey 1
Y TR4/4A Adjusting valves on a TR-4 Triumph 4
