Adjusting Front Suspension
mylesw
Hello
I have adjustable shock tower plates on my Healey and would like to alter the camber of the front suspension. Can I do this with the springs in situ or do I need to remove them? There is also a small bolt on the inside of the shock tower - is this what I use to do the adjustment? I'd be grateful to hear from someone who has done this how it is done.
Thanks
Myles
Which kind of adjustable mounting plates do you have (there is one type that fits into the existing mounting plate, and another that replaces the stock plates altogether). Anyway, you do not have to remove the springs (a big job). Get the car up on 4 jack stands, with the front two placed solidly under the A-arms, preferably near the bottom trunnion of the king pin. Use obvious safety precautions: stands should be on flat, smooth concrete, car should be level and stable. Then, you can do the adjustment. I've done this several times with no problems; my BJ8 rode through a Richter 5 earthquake on jack stands.
maxwedge5281
not to hijack the thread but is one adjustable plate better than the other? and who makes the bolt on plate? seems it would be easier for a diyer than the weld on plate but maybe not as steady!
steveg
BoyRacer
If you have adjustable shock tower plates then all you have to do is screw in, or out, the bolt on the inside to make your adjustments. No need to jack the car up. Just roll it back and forth to take the resistance out of the tires as you make the changes. You can actually eyeball your camber. Adjust the plates so your tires are straight up....90 degrees to the road.....zero camber. As for the plates that Tom's Imports sells, they are not adjustable.
Hoghead
I have a set of the Kilmartins/Moss plates for sale
New and unused
350.00 + shipping from Vancouver Canada
Was going to list on Ebay this week so this is a timely post
Were they built correctly? Some of the Kilmartin plates were built with the rebound rubber on the wrong side. Since the plates have a bit of caster built in they either have to be mounted with the rebound rubber on the 'wrong' (front/back) side, or you have to modify the plates. We were sold a couple of the incorrect ones, and Greg acknowledged the error but offered nothing else.
M
mylesw
Thanks for your replies on this. The adjustable plates are from Denis Welch and have the adjustable screw on the inside of the tower. I will loosen the shock bolts and then try to use the screw to adjust the camber.
Thanks
Myles
Patrick67BJ8
Thanks
Myles
Maybe I'm missing something but are you guys talking about adjusting your camber? If "yes", why not use the Offset Trunion Bushes?
https://www.bighealey.co.uk/austin-healey/suspension-1/front-suspension?page=2
steveg
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
AUSMHLY Adjusting Valve Clearance Austin Healey 31
S Testing and Adjusting procedure for RB340 Austin Healey 4
doc50 Adjusting play on steering box? Other British Cars 5
T Adjusting windows/tops etc. for comfortable highway travel Austin Healey 10
BN6_2197 Adjusting Rer Brake of BN6 Austin Healey 2
BN6_2197 Rookie question on adjusting valve clearance Austin Healey 9
Jim_Gruber Adjusting Spridget Doors Spridgets 4
Tinkerman TR2/3/3A TR3 A 1960 adjusting apron Triumph 4
drooartz General MG Alternator link - adjusting bracket length on MGB? MG 8
Joe Reed MGB Adjusting the reverse lamp switch... MG 3
vette Adjusting HD8 Carbs Austin Healey 21
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
Geo Hahn TR2/3/3A Steering Box Adjusting Screw Triumph 12
RJS TR4/4A Setting up Self Adjusting Slave Cylinder Triumph 6
Jim_Gruber Adjusting Pushrods in Pedal Box Spridgets 5
B Adjusting SU-HD6 Carbs Austin Healey 2
S TR2/3/3A little adjusting screw tr3 Triumph 1
F Adjusting gear lever, centershift 3000 Austin Healey 2
L Adjusting the bows before top installation Austin Healey 2
bighealeysource Adjusting toe in on a Healey Austin Healey 8
M Adjusting TR3 regulator Restoration & Tools 1
Scotsman Adjusting clutch pedal travel Triumph 2
R Adjusting Valve Clearances Triumph 13
Moseso TR2/3/3A Adjusting Koni shocks [TR3] Triumph 10
N Adjusting headlights on a BJ8 Austin Healey 2
A Adjusting BJ8 Doors Austin Healey 5
K TR2/3/3A TR3 Fuel Gauge Again.....Adjusting? Triumph 11
B TR2/3/3A 57 TR3 BONNET ADJUSTING SHIMS Triumph 4
drambuie Adjusting steering box with shims Austin Healey 6
brgrmyster TR6 Adjusting TR6 Headlights Triumph 8
M Adjusting idle speed Triumph 28
bighealeysource adjusting the handbrake on BN6 Austin Healey 1
TR6oldtimer Adjusting rockers Triumph 7
Darwin Adjusting steering play? Triumph 7
hondo402000 TR6 adjusting windows to Wind screen TR6 Triumph 2
T Adjusting valves makes me more crazy. Triumph 18
wangdango 100m bonnet fitting/adjusting?? Austin Healey 4
JohnnyMead Tips on Adjusting the Clutch Slave Pushrod? Triumph 4
pjsmetana Low Idle, DVG adjusting = no dice Triumph 12
pjsmetana Adjusting the Bonnet and the Bumper Triumph 5
DarwinT Adjusting a Weber carb Spridgets 3
bighealeysource ADJUSTING THE HAND BRAKE ON A BN1 Austin Healey 1
Y TR4/4A Adjusting valves on a TR-4 Triumph 4
