TR2/3/3A 56 TR3 Intake and Exhaust Manifolds
mgedit
Was just working on my exhaust system. I can't get the stud that holds the two manifolds together installed. The two holes in the respective manifolds are not aligning. I've enlarged the hole in the exhaust manifold a bit to increase clearance but it is still not close to fitting. Both fit well against the head, I don't think that torquing the manifolds on to the block will align them as the surfaces are pretty much flush now. How critical are those two studs? Do I really need them? Any one else run into this problem? Any ideas or suggestions? Cheers, Mike
Deleted member 8987
Did they fit before?
Did you have the manifold surfaces milled?
mgedit
mgedit
Got the stock manifold from a friend. Car came with a stainless header what ran too close to the starter and generator for my liking so went back to a stock setup. Other than that no changes that I'm aware of. Cheers, Mike
Deleted member 8987
Stock exhaust manifold from another car, stock intake that was on it, right?
One of the exspurts will know better of manifold variations by year.
I would have thought that one had it's surface milled several times over the years...that will do it, too.
M_Pied_Lourd
There's always something eh Mike :smile:
Cheers,
Tush
mgedit
mgedit
I don't think there has been any milling, but who know for sure.
You are right Tush ... this little bolting up project was supposed to be an easy "accomplish something" this afternoon adventure.
Cheers, Mike
Darrell_Walker
In my opinion, the connection is not critical. I've heard that it was to get a little heat into the intake (from the exhaust), but anyone running headers doesn't have it, and I've not heard of any problem attributed to the lack of the connection. It is possible that it provides a little support to the intake manifold as well, but given the geometry, I don't see it adding much.
TR3driver
Great Pumpkin - R.I.P
My suggestion: leave them out unless you plan on driving a lot in freezing weather. Only needed to heat the intake manifold, which helps keep fuel from dropping out of the mixture and forming a puddle on the bottom of the manifold. In theory that could cause stumbling when you open the throttle suddenly, but I never noticed any problem even in below freezing weather.
I was under the impression that the exhaust manifold stayed the same, from the introduction of the TR3 until the TR4A. But I could be mistaken, or you could have a TR4A intake, I guess.
You might also double-check that something isn't hanging up and holding a manifold out slightly. IIRC the exhaust manifold sometimes fouls on the lip of the block, where it protrudes slightly beyond the face of the head, especially if the head has been milled to increase compression. I've also had problems where the locating pins would only go partway into the intake manifold holes.
mgedit
mgedit
Thanks for the input. I did not think of heat transfer as being a reason for including the studs. I was thinking more about structure. I'll double check that there are no ridges anywhere and likely just proceed without the studs. Cheers, Mike
MGTF1250Dave TR2/3/3A TR3 Intake Exhaust Manifold Studs Triumph 9
K For Sale Triumph TR3 Intake Manifold Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale Long and short TR3 and 4A Intake manifolds Triumph Classifieds 0
K For Sale TR3 Intake Manifolds..... Triumph Classifieds 0
O TR2/3/3A TR3 Intake Clearance. Triumph 6
O TR2/3/3A TR3 Intake Clearance Triumph 4
O TR2/3/3A TR3 Intake Fitting Triumph 4
PatGalvin TR2/3/3A TR3 Intake Manifold - how to keep it looking good? Triumph 5
M TR2/3/3A ???? TR3 Intake manifold port matching???? Triumph 6
D TR4/4A TR4 intake manifold on TR3. Triumph 3
