1st things to look for before driving...
robdmau
Just picket up a 1965 Austin Healey Sprite. It is in the body shop getting a new coat of paint. I'm looking for a little help as to what are some key things to look for before taking her on the road for the 1st time. I know I'm going to replace the driver rear brake cylinder and rebuild the master brake/clutch cylinder. I will be taking all four tires off and inspecting the brakes, probably replace the brake fluid and bleed the brakes, also going to do an oil change with a new filter.
Looking for help as far as:
What kind of oil should go in?
Can I get an oil filter at AutoZone?
Type of brake fluid?
Any other recommendation you think I should do before driving her for the first time?
Deleted member 8987
One axle's worth.
Been doing this too many years.
Anything done to the brakes must be done on both sides of one axle.
Shoes, cylinders (rebuild or new), springs, hoses (front).
You rebild/replace one w/cyl, guaranteed, unless everythging is new and it's just a "defective" unit, you will blow the other side in short order.
Jer
This is what I use in my Midget(s)
80/90 Gear Oil in Rear Diff. (what ever is on sale)
30 Motor Oil in Tranny (what ever is on sale)
20/50 Motor Oil in Motor(what ever is on sale)
Dot 3 Brake Fluid is typically used, unless someone has switched over to something fancy on the car.
I buy whatever is on sale as oil in Spridgets are actually there for a short time before it is leaking or burning off :smile: - It's there for a good time, not a long time !
Oil Filter for yours originally is a canistor/cartridge type assembly, the cartridge can be ordered by any jobber or you could just order from the usual suspects (VB, Moss etc.)
Check the tranny fluid level as it is often overlooked, & a full grease job (including steering rack) is a given also. & ... brake, clutch,engine, tranny, rear diff & radiator fluid levels... oops & yes,carb dampner fluid levels.
As long as you have topped up fluids & grease that'l help you out for a first run.
Jim_Gruber
Unless you've got a Spin on Filter Adapter you'll need to order from MOSS or VB. Old style cannister filter messy to change.
Brake Fluid - Castrol LMA
Oil 20W/50W, 3.5 Qts I believe
Valvoline VR-1 has high levels of ZDDP needed to support our old engines
Hoses, hoses, hoses, they collapse internally and don't let the fluid through, replace all 3 Brake Hoses.
CLutch - Castrol LMA as well - Flush and Bleed as well as brake fluid
Jim_Gruber
There is a good section in the WIKI I Believe on steps needed to be done before you attempt to start a Spridget that has been hibernating for years.
robdmau
robdmau
Perfect, thanks for all the pointers...
histerical
Just curious, but why would you have the car painted before doing any of the work needed to get it running and on the road ?
HAN8L1965
Everything I have read is the same oil in the tranny as the engine 20/50. Other than that I agree with all of the above and oil goes in the steering rack not lube.
Mark
twas_brillig
Have a look at your points and timing and look at the plugs for surprises; check the age of your tyres and get real interested if they're more than about 7 or so years old; do a search in here regards tyre pressures as the manual was for bias ply; jack up the front end and give all the wheels a good shake and look for play; check your rad fluid for level and condition; make sure the brake lights work. As mentioned above, fluids are key.
Priorities: 1 - does it stop? 2 - does it turn? 3- will it start? 4 - does it run?
And for your own joy, do a search here as well for a beautifully written Kijiiji Midget for sale ad, and have fun!
Doug
AUSMHLY 1st Motion Shaft Bearing Austin Healey 7
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
M T-Series MG TD 1st/2nd sliding hub end play MG 1
AUSMHLY Remanufactured Laygear with welded 1st gear Austin Healey 20
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
AUSMHLY 1st Motion Shaft Play Austin Healey 3
Hamish Racing 1st sprint of the season Racing 10
TomMull TR2/3/3A 1st gear again Triumph 3
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
KVH General Tech Grinding Gears in Shift From 1st to 2nd Triumph 13
P TR2/3/3A Help needed. TR3A transmission popping out of 1st gear Triumph 13
JPSmit 1st Gen Acura NSX - spotted Other Cars 1
Tom74TR6 Off Topic British Cars and Coffee in North Salem NY Nov 1st MG 0
Tom74TR6 Off Topic British Cars and Coffee in North Salem NY Nov 1st Triumph 9
Tom74TR6 British Cars and Coffee in North Salem NY Nov 1st Jaguar 0
Tom74TR6 British Cars and Coffee in North Salem NY Nov 1st Austin Healey 0
C Looking for 1st British sports car TVR 6
R bj7 hard shifting into 1st & 2nd gear Austin Healey 6
J BN2 Tranny Jumping Out of 1st Gear Austin Healey 1
H 1st and 2nd gear problems Austin Healey 5
Jer Another Co-Pilot, New Parts & 1st Ride Spridgets 10
6 It's snowing, 1st real one here! Spridgets 5
Jer Wife's 1st drive alone in Bridget Spridgets 7
Randy Harris Congrats AUSMHLY on another 1st Place! Austin Healey 7
hilsideser Rochester Hills, Michigan on June 1st Spotted 0
J Buying a Sprite as 1st time classic car buyer Austin Healey 10
doates 1st Real Drive Triumph 7
kodanja 1st Drive of 2011' Triumph 4
JPSmit 1st time - 1500 engine on ebay. Spridgets 13
rikiwho123 starting rebuilt 1300 for 1st time Triumph 7
RickB MGB-GT 1970 MGB GT restored by Chris Longo - 1st in show! MG 10
prb51 1st oil change on rebuilt motor Triumph 4
Tr4dude TR4/4A anybody want 1st crack on tr4 bitsbefore fleabay Triumph 2
R lost 1st and 2nd! Spridgets 10
NardisCNC 1st Time Overhaul / Performance questions?? - 1275 Spridgets 17
NardisCNC Gearbox Noise in 1st!! - Is this normal?? Spridgets 13
Westfield_XI 1st Drive in 11 replica !! Lotus 16
Westfield_XI 1275 firing order- help needed for 1st start! Spridgets 9
Got_All_4 Used my Color Tune for the 1st time. Sweet! Triumph 10
T New member, 1st question MG 19
theleisure Stuck in 1st Gear Spridgets 11
toysrrus My sons 1st. Classic Car: `87 Alfa-Romeo Milano Other Cars 44
jngeorge Our 1st Rd Trip in our new Daily Driver MG 6
N 1947 Norton Fired up for 1st time British Motorbikes 8
George Zeck She now has a pedigree [1st Place] ...... Spridgets 8
BugEyeBear 1958 BugEye 1st Road Test Vintage BMC Video Spridgets 0
MTribe 1st start after rebuild, smoking exhaust manifold? Triumph 7
aeronca65t 1st Race in '08 Spridgets 1
