1st Drive in 11 replica !!
Westfield_XI
After more than 3 years of building, 2 complete moves, and untold hours (does sitting with a beer in the garage problem solving/designing count as man-hours?) my Westfield eleven took to the road this morning. It was just a short trip around the block and back into the garage, but it drove under it's own power!
I have a 1 day trip permits for Friday and Monday (Thursday today) and will go over to another eleven owner's garage to set-up the alignment and the suspension geometry. We will also verify the timing and synch the carbs. The engine is an APT 1380 that gives 97hp on 87 octane and was run in on their dyno. I built and installed a MegaJolt electronic ignition and removed the distributor, so it's running on a digital mapped system. The transmission is a Datsun 5-speed and I am running 15" Dunlop race tires (I hope the CHP don't make a fuss!).
I have a CHP appointment on Monday so there is a chance of getting my plates on Tuesday and then I can see about putting some miles on it. Looks like the Rock Store and the Malibu hills will have to wait until next weekend
I will post up a link to some pictures in a couple of days after I finish up doing the interior install, probably on Saturday morning.
Platinum
WoOT-w00t!!!
Congrats!!!!
...and YES, the beer accompanied cogitation time COUNTS. :thumbsup: :cheers:
drooartz
Fantastic!
I'm with Doc -- the beer/thought time always counts!
glemon
Way cool, one of those things I have on my list to do, but don't know if I will ever get to it. Pictures? As fun as you thought it would be?
tony barnhill
Great Pumpkin - R.I.P
Man, a Lotus 11 replica has gotta be one sweet ride.....can't wait for the photos.
aeronca65t
Great! I've seen a few of these and they are truly a neat car. Wuld love to have one if time and space allowed.
Don't feel bad about taking 3 years.
My friend (and fellow racer) Dave Belden took over 25 years to build his Lotus Mk. 9. Or rather, rebuild it...it's not a replica.
Since it's sort of the grandfather of your car, I thought you might be interested.
Dave saw the car race (and win) when it arrived here in the US in 1955 and was very taken with it.
Twenty five years later he had the chance to buy "the pile of bits" that had been the car.
He jumped at the chance.
He retired a few years back and finally got it together.
He tells me it is easy to drive reasonably quickly.
Here's a race video below with Dave's Mk. 9 in it. Dave got a bad start and I passed him, but he got by again in the video about a minute later.
~Race Video~
drooartz
:iagree:
'cept if you're hiding from a wife.... :devilgrin:
Then it counts twice!
Alphonse
I believe there's a chapter or section in every Lotus service manual about using the correct lubricants.
Therefore I concur with the properly applied usage of the proffered libation.
tony barnhill
I spend lots of time with beer & thought! More time than building cars!
BabaKahawa
DrEntropy said:
WoOT-w00t!!!
Congrats!!!!
<span style="font-weight: bold">Beer time in the garage always counts, Fantastic !!!!!!!!!</span>
:thumbsup:
Westfield_XI
Westfield_XI
Re: 1st Drive--- Pictures & progress report
Thanks, for the support. The bottom line is that I failed the inspections, CHP was fine, they verified the VIN and didn't see the race tires. The headlight/brake inspector wants me to install the E-brake (it's on the shelf in Tucson) which is no problem, but they also want me to raise the headlights by 5 inches. I am at 17" and I need to be at 22" minimum. I think I can get this by screwing in the front spring preload and by lifting the front clamshell on it's mounts. It only has to be like that until it passes inspection and then I can lower it back to the correct ride height.
The Bureau of Auto Repair referee says I need a functioning PCV system before he will sign off on my smog exemption. I can just hook up a quick a dirty system to a port on the back of a K&N, or make up a proper vent system with a catch tank and vent that to the intake. Either way it shouldn't be too hard.
So I am heading back to Tucson and leaving the car here until after Xmas when I will return and correct all the discrepancies and get my plates. Then it's back to AZ to drive it all winter and spring while polishing up the fiberglass gel coat and re-doing the factory interior.
Here is a link to my latest pictures: https://s411.photobucket.com/albums/pp192/Westfield11builder/Westfield%2011/Fall%202009/
Alphonse
You are obviously gifted with a great suppply of patience.
A much needed character trait for Lotus and it's many off-shoot manufacturer owners.
Good luck with the project.
Al B.
Camshaft
Congratulations! I remember when you started this project. I'm really excited to hear it's on the road!
78Z
Sounds like you are almost there. Looks fantastic. I'll bet the first drive was great. My greatest worry about my Seven project is the registration/insurance bit. Ugh.
Jer Wife's 1st drive alone in Bridget Spridgets 7
doates 1st Real Drive Triumph 7
kodanja 1st Drive of 2011' Triumph 4
AUSMHLY 1st Motion Shaft Bearing Austin Healey 7
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
M T-Series MG TD 1st/2nd sliding hub end play MG 1
AUSMHLY Remanufactured Laygear with welded 1st gear Austin Healey 20
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
AUSMHLY 1st Motion Shaft Play Austin Healey 3
Hamish Racing 1st sprint of the season Racing 10
TomMull TR2/3/3A 1st gear again Triumph 3
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
KVH General Tech Grinding Gears in Shift From 1st to 2nd Triumph 13
P TR2/3/3A Help needed. TR3A transmission popping out of 1st gear Triumph 13
JPSmit 1st Gen Acura NSX - spotted Other Cars 1
Tom74TR6 Off Topic British Cars and Coffee in North Salem NY Nov 1st MG 0
Tom74TR6 Off Topic British Cars and Coffee in North Salem NY Nov 1st Triumph 9
Tom74TR6 British Cars and Coffee in North Salem NY Nov 1st Jaguar 0
Tom74TR6 British Cars and Coffee in North Salem NY Nov 1st Austin Healey 0
C Looking for 1st British sports car TVR 6
R bj7 hard shifting into 1st & 2nd gear Austin Healey 6
J BN2 Tranny Jumping Out of 1st Gear Austin Healey 1
H 1st and 2nd gear problems Austin Healey 5
Jer Another Co-Pilot, New Parts & 1st Ride Spridgets 10
6 It's snowing, 1st real one here! Spridgets 5
Randy Harris Congrats AUSMHLY on another 1st Place! Austin Healey 7
hilsideser Rochester Hills, Michigan on June 1st Spotted 0
J Buying a Sprite as 1st time classic car buyer Austin Healey 10
robdmau 1st things to look for before driving... Spridgets 10
JPSmit 1st time - 1500 engine on ebay. Spridgets 13
rikiwho123 starting rebuilt 1300 for 1st time Triumph 7
RickB MGB-GT 1970 MGB GT restored by Chris Longo - 1st in show! MG 10
prb51 1st oil change on rebuilt motor Triumph 4
Tr4dude TR4/4A anybody want 1st crack on tr4 bitsbefore fleabay Triumph 2
R lost 1st and 2nd! Spridgets 10
NardisCNC 1st Time Overhaul / Performance questions?? - 1275 Spridgets 17
NardisCNC Gearbox Noise in 1st!! - Is this normal?? Spridgets 13
Westfield_XI 1275 firing order- help needed for 1st start! Spridgets 9
Got_All_4 Used my Color Tune for the 1st time. Sweet! Triumph 10
T New member, 1st question MG 19
theleisure Stuck in 1st Gear Spridgets 11
toysrrus My sons 1st. Classic Car: `87 Alfa-Romeo Milano Other Cars 44
jngeorge Our 1st Rd Trip in our new Daily Driver MG 6
N 1947 Norton Fired up for 1st time British Motorbikes 8
George Zeck She now has a pedigree [1st Place] ...... Spridgets 8
BugEyeBear 1958 BugEye 1st Road Test Vintage BMC Video Spridgets 0
MTribe 1st start after rebuild, smoking exhaust manifold? Triumph 7
aeronca65t 1st Race in '08 Spridgets 1
