1st Real Drive
doates
The sun finally came out here in Northern California so I played hooky from work and took the wife for a drive. In the six years that I have owned the car this is the 1st time I have covered more than 20 miles in a day and maybe the 3rd time that my wife has been in the car.
It was great! First 20 miles on the freeway at about 65 mph (speedometer said 70) were smooth, overdrive worked perfectly; only minor vibration from the drive shaft that I cut down and welded myself. I took the freeway because I wanted to be able to tell Hagerty tow service what road I was on. Didn't need to.
Putted around Petaluma a bit; stop and go, traffic, etc. Idle is a bit low so when at a stop light it felt like it wanted to stall, but never did.
Took country roads for the 40 mile trip home and it ran beautifully. My wife was thrilled. She bought the car for me for Christmas and had never really ridden in it.
There are some glitches to be sorted out; I will be asking you guys for help with but all in all it was a really nice day:
1) The brakes need a lot of help
2) There is a chirping noise from right front wheel - sounds a little like a brake squeeler that is just beginning to touch - more so on a left hand turn - all new brakes
3) Drive shaft is rubbing against the tunnel, just at the back of my seat, at certain bumps and under certain loads - I actually wonder if I need to change my rear springs
4) None of the lights on the front half of the car work
5) Smells a little rich
Thanks for your help in getting the Spit back on the road
Dennis
DNK
doates said:
... I took the freeway because I wanted to be able to tell Hagerty tow service what road I was on.
Spoken like a true Rumphy
TexasKnucklehead
Sweet.
Sounds like some minor problems... Except those brakes, noises and smells.
Make it safe. By then, you'll be used to those brakes, noises and smells.
GilsTR
Dennis...Congratulations on the ride. Yesterday was really nice with SUN! You should continue to find help here on the forum as you sort thru things. Why not mark down the UBSCC All British Car Show over in Woodland on your calendar!
Gil NoCal https://www.ubscc.org/CarShow.htm
doates
doates
Gil,
I attended that last year; found out about it here. Talking to some really friendly Spitfire owners at the show is one of the things that inspired me to restart work on the Spit and get it back on the road. Has it been a year already?
6 It's snowing, 1st real one here! Spridgets 5
AUSMHLY 1st Motion Shaft Bearing Austin Healey 7
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
M T-Series MG TD 1st/2nd sliding hub end play MG 1
AUSMHLY Remanufactured Laygear with welded 1st gear Austin Healey 20
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
AUSMHLY 1st Motion Shaft Play Austin Healey 3
Hamish Racing 1st sprint of the season Racing 10
TomMull TR2/3/3A 1st gear again Triumph 3
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
KVH General Tech Grinding Gears in Shift From 1st to 2nd Triumph 13
P TR2/3/3A Help needed. TR3A transmission popping out of 1st gear Triumph 13
JPSmit 1st Gen Acura NSX - spotted Other Cars 1
Tom74TR6 Off Topic British Cars and Coffee in North Salem NY Nov 1st MG 0
Tom74TR6 Off Topic British Cars and Coffee in North Salem NY Nov 1st Triumph 9
Tom74TR6 British Cars and Coffee in North Salem NY Nov 1st Jaguar 0
Tom74TR6 British Cars and Coffee in North Salem NY Nov 1st Austin Healey 0
C Looking for 1st British sports car TVR 6
R bj7 hard shifting into 1st & 2nd gear Austin Healey 6
J BN2 Tranny Jumping Out of 1st Gear Austin Healey 1
H 1st and 2nd gear problems Austin Healey 5
Jer Another Co-Pilot, New Parts & 1st Ride Spridgets 10
Jer Wife's 1st drive alone in Bridget Spridgets 7
Randy Harris Congrats AUSMHLY on another 1st Place! Austin Healey 7
hilsideser Rochester Hills, Michigan on June 1st Spotted 0
J Buying a Sprite as 1st time classic car buyer Austin Healey 10
kodanja 1st Drive of 2011' Triumph 4
robdmau 1st things to look for before driving... Spridgets 10
JPSmit 1st time - 1500 engine on ebay. Spridgets 13
rikiwho123 starting rebuilt 1300 for 1st time Triumph 7
RickB MGB-GT 1970 MGB GT restored by Chris Longo - 1st in show! MG 10
prb51 1st oil change on rebuilt motor Triumph 4
Tr4dude TR4/4A anybody want 1st crack on tr4 bitsbefore fleabay Triumph 2
R lost 1st and 2nd! Spridgets 10
NardisCNC 1st Time Overhaul / Performance questions?? - 1275 Spridgets 17
NardisCNC Gearbox Noise in 1st!! - Is this normal?? Spridgets 13
Westfield_XI 1st Drive in 11 replica !! Lotus 16
Westfield_XI 1275 firing order- help needed for 1st start! Spridgets 9
Got_All_4 Used my Color Tune for the 1st time. Sweet! Triumph 10
T New member, 1st question MG 19
theleisure Stuck in 1st Gear Spridgets 11
toysrrus My sons 1st. Classic Car: `87 Alfa-Romeo Milano Other Cars 44
jngeorge Our 1st Rd Trip in our new Daily Driver MG 6
N 1947 Norton Fired up for 1st time British Motorbikes 8
George Zeck She now has a pedigree [1st Place] ...... Spridgets 8
BugEyeBear 1958 BugEye 1st Road Test Vintage BMC Video Spridgets 0
MTribe 1st start after rebuild, smoking exhaust manifold? Triumph 7
aeronca65t 1st Race in '08 Spridgets 1
