T-Series 1974 mgb ignition switch/lock w/harness
mirceme
My ignition switch is shot and the previous owner replaced it with a simple toggle switch.
I bought a replacement but need to find out how to remove the current lock. It appears to be fastened with some sort of headless bolt.
Any suggestions as to how to back out the old fasteners?
GavinR
Member
Yep, get a small chisel or punch and a hammer and tap them round in the same direction as you would a regular bolt. once you've got them stared they'll usually turn using your fingers quite easily. They're called shear bolts and are there as an anti theft measure.
GavinR /ubbthreads/images/graemlins/england.gif /ubbthreads/images/graemlins/canpatriot.GIF
NC Mike
mirceme,
If you have any luck with the chisel routine, than you're more adept at using one than I am. Let me make two other suggestions.
Having recently removed and rebuilt the ignition switch in my 74.5 MGB-GT, I have a pretty good idea about how to remove it.
If you have a Dremel tool, or can borrow one from a friend, than you have the best tool for the job.
Based upon your description, you have removed the steering column covers to gain access to the switch. The "headless" bolts are referred to as shear bolts like Gavin mentioned, but I believe they were used less for anti-theft as they were to facilitate faster assembly. Since the heads shear off at a predetermined torque, they could be installed without having to use a torque wrench. Installers just kept turning untill the head twisted off.
Back to your question...
The bolts are made of aluminum or some other soft metal, and cut rather easily. Install a cutting disc in the Dremel tool and carefully cut a straight slot all the way across the top of each bolt. If you make the cut with a new disc, and cut as deep as you can without cutting the flange surrounding the bolt, you should should be okay.
Using a flat blade screwdriver with a blade width as close to the bolt diameter as you can find, unscrew the bolts.
I used this technique about three weeks ago, and the bolts screwed out easily.
YOU MIGHT NOT HAVE TO REMOVE THE SWITCH HOUSING
If you have a key that fits the "bad" ignition switch, and it still functions with respect to locking and unlocking the steering column, then you might not have to remove the original switch housing.
What you're calling the switch is made up of three basic components: 1- a keyed cylinder (where the key goes), 2- the housing (mounted with the shear bolts), 3- the actual electrical switch (black plastic piece with the wires soldered to it).
If your replacement switch is identical to the original, then you can save yourself some time this way.
The electrical portion of the switch is obviously at the opposite end from the key. Looking at your original equipment switch housing, you'll see a small, number 1 phillip's head screw close to the edge of the housing, at the switch end. Removing this screw will allow you to slide the electrical portion (the actual switch) out of the housing.
The connection between the switch and the ignition key cylinder is a t-shaped male/female interface that will allow the switch to be removed in this manner. At most, you might have to insert the key and give it a little twist back and forth while pulling the switch away from the housing.
With the original switch removed, you can install the new switch just as easily by reversing the proceedure.
Of course, this is based upon your replacement being constructed the same way as the original.
You'll find that the switch's wire harness is taped to the steering column with a wrap or two of black electrical tape, and that the connection is beneath the edge of the dashboard to the left of the column. The connector separates easily, just look twice at the little plastic "levers" on each side to make sure you're releasing them instead of holding them on tighter.
Hope this helps,
Mike
M
mirceme
Thanks for the help/suggestions.
I was able to remove the shear bolts with a chisel quite easily. The new assembly fit perfectly and had everything back together and working great in a minimum amount of time.
Thank you again
Writey
How to remove the actual ignition barrel? I am hoping to see a number to get a new ignition key cut, as original key is lost. 1974 MGB roadster with ro-style wheels.
Platinum
Where did you cut the slot on the bottom of the lock? Can a chisel be put between the half's and break the shear bolt?
The slots are cut in the two shear bolts only. The main body of the lock assembly is soft metal, it will be destroyed if split and likely exacerbate the problem. One way to remove the shear bolts is with a drill and easy-out. Another way is a left-twist drill bit. That last will usually unwind the bolts with least effort, the drill will "catch" in the bolt and do the work.
PAUL161
Deleted member 28450
I have just replaced my ignition switch, and to remove the headless bolts I tapped them round with a centre punch, once they move they are dead easy to remove. Once I had them out I cut a slot in them with a hacksaw and refitted with a ordinary screwdriver
PAUL161
Somewhere I have a tool that was designed to remove and install the so-called "headless" bolts. It is still used today in commercial bathrooms and buildings to deter anyone from removing that type of fastener to damage bathroom equipment etc, haven't seen it in years.
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
VeeCee MGB 1974 MGB Roof Installation MG 0
P MGB 1974 MGB front spring length. MG 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
A MGB MGB 1974 windscreen centre rod replacement MG 5
HAN5L778 MGB 1974 1/2 MGB Project car MG 0
J MGB 1974 1/2 MGB gasoline type MG 5
wkilleffer MGB 1974 MGB convertible top anchor bar size MG 4
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 11
wkilleffer T-Series Clutch pipe installation- 1974 MGB MG 2
N MGB 1974 MGB Questions MG 5
K T-Series Trailer Hitch for 1974 MGB Roadster MG 4
Monark192 MGB 1974.5 MGB vs. 1975 model. Which to keep? MG 19
wkilleffer MGB 1974 MGB distributor drive dog- which one is it? MG 8
wkilleffer MGB HS4 carb question- 18GK engine, 1974 MGB [long] MG 6
wkilleffer MGB MGB 4-way fuse box question- 1974 MGB MG 8
C MGB-GT 1974 1/2 MGB GT MG 37
1 MGB 1974 MGB in Florida MG 15
7 MGB My Project Car 1974 MGB Convertible MG 50
C MGB 1974 MGB ready for lots of work and help with questions:] MG 6
D Trying to get back working on the 1974 Midget Spridgets 11
A For Sale 1974 TR6 Triumph Classifieds 1
Marvin Gruber For Sale 1974 TR6 for sale, $7200 Triumph Classifieds 3
D For Sale 1974 triumph spitty davidschab60@gmail.com Triumph Classifieds 0
J 1974 Jensen Other British Cars 22
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
C For Sale 1974 TR-6 Project car for sale whole Triumph Classifieds 0
H TR6 1974 tr6 allison xr700 Triumph 12
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
R SOLD!! 1974 Jensen Healey Other British Classifieds 0
bravenrace For Sale 1974 TRV 2500M FOR SALE Other British Classifieds 2
krswen For Sale 1974 Panther J72 Other British Classifieds 4
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
S For Sale MG Midget Workshop Manual on CD/ROM - 1962 - 1974 Models MG Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Spridgets Classified 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Austin Healey Classifieds 0
A 1974 2500M Spring Rates TVR 6
L TR6 1974 Tr6 ignition switch Triumph 3
T TR6 ajustable training arm brackets--- 1974 TR6 Triumph 14
C I'm looking at a 1974 MG Midget [chrome bumpers with black sabrinas] Spridgets 9
B 1974 Midget Spridgets 6
jmayzer For Sale 1974 MG Midget Mk III [Maryland, USA] Spridgets Classified 1
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
M 1974 Jensen INterceptor electrical help needed Other British Cars 8
F MGB Correct steering wheel - 1974 MG 2
AngliaGT 1974 Midget - It's ALIVE!!! Spridgets 7
