100M Cold Airbox Filter
TomH
My 100M has higher HP and compression than standard. I am filtering the air intake with Denis Welch's adapter and ITG filter, but I find that the filter restricts the air flow too much. Any recommendations for a better flow through filter would be greatly appreciated.
GregW
Hi Tom,
Welcome to the Forum. What makes you think the filter is restrictive? Maybe a K&N filter like THIS would work better for you.
T
TomH
Thanks Greg. Performance is significantly improved with the filter removed. I experience hesitation with the filter installed. The filter I need would fit inside the air box duct hose.
GregW
You want to put the entire filter <span style="font-style: italic">inside</span> the hose? If you have that setup now and you are using the DW hose that is 4.5" diameter, that maybe your problem. For your engine displacement and redline (170 CID approx. and 5300RPM) you'd want a minimum of 44 square inches of filter area. The hose has a little less than 16 square inches in its cross section.
P.S. That first filter I mentioned is way bigger than you'd really need.
glemon
Can you put one of those end of the hose type filters at the hose intake in front of the radiator and remove it when you show the car? As stated you might have restriction issues if you are looking to put a filter in the hose itself.
I know that was not your stated intent, but the hose end type filters are pretty common from K & N etc.
Afew minutes or miles of running on paved roads without a filter should not hurt things.
Michael Oritt
I use a cone-shaped foam filter that goes into the fromt end of the hose, mounted right up against the grill. I can reach in through the wheel well and remove it for cleaning.
AH100M
Sounds interesting - can you give me more details on the filter - manufacturer, part number, etc.? I assume it fits the stock cold air box hose fit to the 100M.
Thanks
Michael Oritt
"Agreed. Can you furnish us with the filter info Michael?"
I got it from Denis Welsch several years back. I'll try to remember to measure the OD of the piece or the ID of the hose tomorrow--maybe even a photo from Santa if you're real nice.
Michael Oritt
Tom--
Sorry, I forgot to take that picture and if I am at the shop tomorrow I will try to remember!
In any case that is the filter that I am using. I have a square to round adaptor (Not DW's--I had it custom made because the DW unit did not make a tight enough bend) at the engine end of the hose and the DW stuck in the grill end secured by a hose clamp.
The DW site says that the filter will work on engines up to 150 HP--is yours putting out that much--that's a lot of HP? If so I assume you feel the filter is restricting air flow and wonder why you reached that conclusion.
T
TomH
Thanks Michael. Not a problem. Performance is like night and day with and without the filter. I experience power loss and acceleration hesitation with the filter installed. I am not certain of the car's exact HP, but it is close to 150.
Michael Oritt
Well that is impressive. I'll send a photo anyway but it looks like I cannot bring anything new to the table.
FWIW when I got my car it had no air filtration whatsoever. After having it rebuilt I thought about those nice smooth bores and all the grit flying around on the road and installed the DW filter. I try to clean it every so often and have been able to wash visible dirt out of it so I think running without some kind of filter is bad business.
Michael Oritt
Here are five photos showing the cold air box to hose adaptor and the filter which I have mounted at the front end of the hose. As you can see it is removable through the wheel well simply by pulling it out and it looks to be the same one pictured on the DW site. This photo shows it behind the grill--just to the right of the flash.
Michael Oritt
Here's #2
Michael Oritt
Michael Oritt
Michael Oritt
GregW
Hi Michael,
Are you using that filter as Denis Welsh had intended? Seems like it is installed backwards. In essence, your only using what I've outlined in the below photo. Since the filter causes resistance to the airflow, you might be starving the engine of air.
Michael Oritt
Hi Greg--
Yes, the cone is installed backwards as I am using it at the bottom (front end) of the hose rather than the top by the CAB. But the filter is normally inserted all the way in the hose as shown in picture #3 and I can't see how that would restrict airflow, though I am always willing to be enlightened. I have no signs of starvation, at least that I know of.
P Healey 100M Cold Air Box Hose Fitting Austin Healey 20
AH100M 100m/100 Le Mans Cold Air Box grommets Austin Healey 5
AH100M 100m Cold Air Box Grommets Austin Healey 2
Bob_Spidell New, and lively, 'discussion' on 'What is a 100M' Austin Healey 5
L The First "Factory" 100M Austin Healey 3
Editor_Reid For Sale 1956 Austin-Healey 100M [real one] Austin Healey Classifieds 0
bighealeysource Question on 100M front brake cylinder Austin Healey 4
lbcspinners Austin-Healey 100M auction on BaT! Austin Healey 36
HealeyRick 100M Brain Teaser Austin Healey 10
Healey Nut This one claims to be a real factory 100M Austin Healey 21
HealeyRick Earl's Court 100M on BaT Austin Healey 16
P 100M overdrive disengages on hot engine/transmission Austin Healey 9
Healey Nut 100m Austin Healey 9
Healey Nut Another 100M Austin Healey 9
W 100M that sold on Bring-a-Trailer aka BaT Austin Healey 13
S Anyone want a Honda 100M? Austin Healey 3
HealeyRick Earls Court 100M in Classic Motorsports Austin Healey 5
HealeyRick Earls Court 100M Austin Healey 9
Bob_Spidell Here we go again!: What is [and isn't] an Austin-Healey 100M? Austin Healey 3
R 100M For Sale RM Monterey Austin Healey 12
A 100M sold by Bonham's in Spa Francochamps Belgium yesterday Austin Healey 2
David Townsend Earls Court 100M Limited Edition Prints Austin Healey 0
bighealeysource Was 100M from Chasing Classic Cars sold this weekend? Austin Healey 20
David Townsend Gerry Coker Signature Now Available on 100M and 100S Collector's Edition Prints Austin Healey 3
H 100M on E-bay Austin Healey 37
David Townsend 100M Illustration Started Austin Healey 32
HealeyRick Another 100M Story Austin Healey 23
magman 100M etched carburettor numbers Austin Healey 4
bighealeysource Number of 100M's registered in 100M Registry Austin Healey 1
Editor_Reid The 100M & the Le Mans Kit & all that rot Austin Healey 37
HealeyRick 100M at The Quail Austin Healey 3
M Original Owner Factory 100M Austin Healey 31
A 100M or not ? Austin Healey 37
AUSMHLY For sale, 100m Austin Healey 31
MikeAH100M Treatment for Leather Bonnet Strap - 100M Austin Healey 9
J 100M Shift Boot Austin Healey 0
MikeAH100M Car Research - 56 100M Austin Healey 5
DerekJ Dealer 100M Austin Healey 16
R Earls Court 100M Sold Austin Healey 19
CLEAH What is a "Dealer 100M LeMans?" Austin Healey 32
MikeAH100M 100M Timing Austin Healey 3
HealeyRick Salad Days for the 100M Austin Healey 7
L 100M Carbs Austin Healey 1
MarshgrassA Another Dealer 100M question Austin Healey 13
bighealeysource Anyone know of a source for correct size "M" for 100M models ? Austin Healey 0
HealeyRick 100M at MM Austin Healey 14
H 100M "Dealer" on e-bay Austin Healey 3
Bob_Spidell Another "100M" ? Austin Healey 23
Editor_Reid 100M Introduction Austin Healey 9
V 100M detailed engine data Austin Healey 3
