G'day Chet,
While I don't wish to sound like I am criticising you for deciding to fit disc brakes to your 100-Six (it is after all, a desirable conversion) I was disappointed not to find out what the original problem was.
In your first post on the subject, you asked if the long pedal was a typical characteristic of twin-leading shoe drum brakes. As you have been advised, it certainly isn't and as Derek Job pointed out this design of brake was considered desirable for high-performance cars before the widespread adoption of disc brakes in the late 1950s. To resort to curing an obviously malfunctioning brake by converting to a different system was not only expensive, but also risky because there was no guarantee that it would solve the problem, should that problem have been elsewhere in the system.
My BN1 has similar brakes to the 100-Six (albeit with narrower linings) and I have rarely had trouble achieving a satisfactory pedal when the job is done according to the manufacturer's procedure (I'm not trained as a mechanic, so getting creative isn't a good idea!). I'm happy to say that I have never had to resort to bench bleeding the master cylinder or using Randy's method of cracking the seal on the connecting pipe. There was obviously something wrong with your brakes and I think we all would have benefited from learning what that very obscure problem was, and the solution.
Cheers from down under. Here's looking forward to being able to enjoy our Healeys again in the near future.
Alwyn
