100/4 front suspension/Mt Washington Hill
sunbeam74
I have a question regarding king pin bushing replacement on a 100/4 suspension. This winter my plan is to rebuild the front suspension entirely. I was going to purchase the Moss king pin kits and noticed there is an expensive reamer available - Is this a requirement? Can a good machine shop setup the bushes and pin?
It seems like the front suspension is pretty straight forward but the $1100 reamer caught my attention. Could there be a trick to this suspension? Please let me know.
I was able to run the Healey-Chevy at the Mt.Washington Hillclimb last weekend. 5 runs up the 5-6 mile coarse. It really was a good time.
https://www.gullwingsearch.com/display.cfm?CategoryID=251
(#74, silver and red stripe - no, it doesn't look like a 100/4)
If you did a modest search on the topic, you'll see that I've posted pictures here several times of the setup I use. In fact, this thread is <span style="font-style: italic">only</span> eighteen (18) threads down and on this same page(!) https://www.britishcarforum.com/bcforum/ubbthreads.php/topics/161720/Kingpin_Reamer#Post161720
I purchased commonly available reamers in the two (2) required sizes and made pilots to fit the opposite end. The point being to keep the upper and lower bushes in perfect alignment. Simple enough.
So to answer your question, a good machine shop <span style="font-style: italic">could</span> setup your kingpins, if they wanted to.
Also, Moss has carried that reamer in their catalog for years, but has not always had it available for shipping. I had inquired about once before, and had actually talked myself into buying one, only to find out they weren't available at that time. Just as well, as it prompted me to act on my own.
S
sunbeam74
Sadly, I did do a modest search using the search engine in the Healey forum using "front suspension" as my search term...:smile: Oh well.
But yes, your post did answer my question.
Steve
C AH 100 Best Options for front and rear suspension? Austin Healey 9
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
P 100/6 Front Wheel Alignment Austin Healey 10
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
L 100/6 replacement front seats Austin Healey 7
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
MikeAH100M 100 Front Hub Spacer/Distance Piece Austin Healey 2
C 100-6 front drum brakes? Austin Healey 36
A Wanted Front Bumper Brackets/Spring bar assembly for 100-6 Austin Healey Classifieds 0
L Front Brake 100/6 Austin Healey 1
D front shocks 100 m Austin Healey 12
T Front transmission seal not on 100-6 Austin Healey 2
cmc140 Austin-Healey 100 front splash pan / splash shield question. Austin Healey 8
T 100 4 Front Sway Bar Austin Healey 12
W 100-4 front main bearing cap issue Austin Healey 5
M 100-4 BN2 Front Fender with extra Groove Austin Healey 2
bighealeysource front disc brakes conversion for 100-4 Austin Healey 21
Y Restoring a 58 100 six front shroud Austin Healey 1
R 100-4 front fender removal Austin Healey 2
T 100 Front Shroud Attachment Austin Healey 0
M Healey 100-4 Front Spring Stiffness Austin Healey 2
bighealeysource 100-4 front shock replacement Austin Healey 2
H Healey 100 Front Wheel Bearing replacement Austin Healey 4
bighealeysource Removing front shocks on a 100 -4 Austin Healey 12
J Does anyone need a front valance for a 100-4? Austin Healey 1
mbrooks 100 oil leak from front of engine Austin Healey 3
Editor_Reid Healey 100 Front Springs Austin Healey 7
timbn2 Front Shroud for 100 Austin Healey 2
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
A 100/6 BN4 Restoration Austin Healey 6
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 7
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
