TR2/3/3A Sealer plate
Dr_Mike
My car's body was reassembled many years ago with bits from Moss and TRF. I am struggling to put on the sealer plates ( from Moss). I have riveted Captive nuts to match the holes in the plate, but on the passenger side there is not enough body sticking out and I will have to use self-tapping/sheet metal screws. The perceived problem is how to fill the space under the sealing plate and around the top edge so that water (and rust ) do not get trapped there. It will not be a very snug fit. Advice needed! Pics will follow tight, I hope.
Dr_Mike
yes, there is a flange dipped into the outer edge, which presses against the wing, and maybe stops it vibrating. there is also a rubber strip riveted to the top.
i'll have to get the pics so you can see what I have got!
CJD
Mine did not match very well either. I fabricated a new plate...which is very easy, since it only has a single bend in it. I then matched it to the contour of the wing, less about 1/2” to allow for the seal. At the top it is a matter of positioning the upper rubber seal to best match the “L” shape it has to fill...and then riveting it into place.
As you can tell, you don’t want the seal to push too heavily against the wing, or it will distort the wing shape. At the top the smaller wing radius makes it less prone to deflection, so it can have more pressure there. I think I still had to slightly trim the upper seal (or lean it forward maybe) to make it fit well.
No matter how well it seals, it will still leak some water behind the plate. Be sure there is enough opening at the rear bottom of the wing to give the water somewhere to go. That, combined with paint should keep the area rust free.
charleyf
If you are willing to use it , you can use spray undercoating to finish that seal to shut out the water.
D TR2/3/3A OD cover plate gasket sealer. Triumph 17
S TR2/3/3A gasket sealer for the bear plate Triumph 7
angelfj1 Bulkhead Sealer Plate Triumph 5
Tinkerman TR2/3/3A Bulkhead Sealer Plate TR3A 1960 Triumph 3
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
S TR2/3/3A temp gauge sealer Triumph 7
B Gasket Sealer on Intake/Exhaust Manifold Gasket. Austin Healey 7
S TR2/3/3A steering box sealer Triumph 9
T TR4/4A Head gasket sealer question Triumph 7
B TR2/3/3A seam sealer front fender and cage muts, undercoat Triumph 7
KVH General Tech Gasket Sealer and Sealants Triumph 6
drooartz Seam sealer for fender beading? Spridgets 9
B Seam Sealer/Caulking - Any Tips on When, Where, and What to Apply? Austin Healey 45
S TR2/3/3A copper gasket sealer and push rods Triumph 10
P What's the best seam sealer to use for panels on bare shell? Restoration & Tools 7
Patrick67BJ8 Sealer between fenders and shrouds Austin Healey 12
PatGalvin Front Wing Sealer Plates Triumph 5
PatGalvin Seam Sealer for Engine Compartment Triumph 21
M Tank Sealer in Alu. Fuel Tanks Austin Healey 4
J Seam Sealer, do I need it? Spridgets 1
KVH Fuel Tank Sealer Triumph 3
DNK Fittings Sealer Triumph 6
B Gas tank sealer...whats your opinion? Triumph 29
TulsaFred Fender beads look kinda lousy, sealer? Spridgets 9
M Water Pump Gasket & Sealer Spridgets 10
Superwrench Rear shroud sealer Austin Healey 3
JohnnyMead Seam Sealer on the Fire Wall Triumph 4
sail Gearbox Sealer Triumph 2
CinneaghTR Oil Pan Gasket Sealer? Triumph 14
V Valve cover gasket & sealer??? Spridgets 11
Tabcon Thread Sealer on Wet Liners? Triumph 5
Tabcon Thread sealer on wet liners? Racing 0
R TR6 TR6 Interior Seam Sealer Issue, Restorers! Step In Triumph 4
D TR6 TR6-windshield frame to bady sealer Triumph 3
1 Removing seam sealer? Austin Healey 6
D Gasket sealer British Motor Corp 2
zimmy primer sealer problem Spridgets 7
T TR6 TR6 water pump gasket - also use sealer as well? Triumph 9
M Gas Tank Sealer Triumph 14
B What Gasket Sealer to Use on Engine Parts? Spridgets 8
zimmy primer or primer sealer.....whats the difference? Spridgets 15
jjbunn Windscreen Capping - Sealer? Triumph 4
C Seam sealer in the Engine compartment? Triumph 1
C Best way to remove seam sealer? Triumph 5
angelfj1 TR2/3/3A 3A Petrol Tank Sealer - Is this necessary Triumph 8
fabmandan Seam sealer question Spridgets 8
C Under body seam sealer? Triumph 2
F Thread sealer Triumph 5
