TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP
decibeldesign
I finally got my TR3 ready for it's road safety check after 3 years since I bought the non-running car. It had it running ok at the time, a bit of oil would drip from the bell housing when it was running but nothing to bad.
Just as I was getting it ready I tried to start it again and it only backfired a couple of times (not just little backfires but pretty loud and violent). I found that a screw had fallen inside the distributor and jammed up the balancers at the bottom of the distributor. I got the screw out and reset everything. It is running again but pretty rough. Any load on the engine and it stumbles etc. But that is the least of it's problem now.
When the motor is running there is a steady drip of fluid coming from the bottom of the bell housing of the Transmission. I though at first either engine or trans. oil but after closer investigation I am pretty sure it is coolant, and plenty of it. It however does seem to be burning coolant, only the usual sooty exhaust, not clouds of white smoke. Note, I am running Evans waterless coolant in it.
Anyone have any idea what might have happened to cause this, and what I might need to do to fix it?
Thanks
TR4nut
I suggest shining a light on the back side of the cylinder head to see if you can spot a leak. There are no openings on the rear of the engine inside the bellhousing that would leak coolant. Oil yes, coolant no. If you have a heater inspect under the dash to make sure everything is dry. Could just be a bad hose.
DavidApp
Is the head gasket leaking at the rear of the motor?
Did the motor have coolant in it while you had it stored?
David
sp53
What does the oil on the dipstick look like? There is also a small metal plate that comes off at the bellhousing that gives a little better view, but it does not seem likely there is coolant coming out there unless the oil has mixed and then it would be milky.
martx-5
There is a freeze plug at the back of the cylinder head that I have seen leak that may be running down the back of the engine. I've seen that replaced in situ using one of those rubber expansion type plugs if you don't want to remove the head.
HighAltitudeTR3
I suggest setting the points, static timing, set carbs. That will make it happy. In terms of leaking coolant from the back... it's either the headgasket or not. And if it's not, then I would start checking the easiest fixes off your list... hoses, seals, etc. eventually you work your way to a solid crack free block. :smile:
double chrck its coolant, I delevoped a leak of clutch fluid. It drips off the secondary clutch solenoid (which is right next to the area you're talking about), but it took me a couple of glances to figure out where it was dripping from.
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
Pool Dad 1960 TR3 engine serial number Triumph 14
Joel Lester TR2/3/3A "TR3" painted on the engine block Triumph 13
K For Sale TR3 Engine Lift Bracket...hard to find! Triumph Classifieds 0
HalLucy Standard Vanguard Sportsman engine and the TR3 Other British Cars 7
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
Moosca TR2/3/3A "56 TR3 Engine Verification Triumph 17
W TR2/3/3A Novice TR3 Engine Rebuild Triumph 47
J TR2/3/3A TR3 engine build Triumph 12
doc50 TR2/3/3A How to verify TR3 engine numbers Triumph 20
6 TR2/3/3A Engine in my TR3 Triumph 15
M TR2/3/3A TR3 engine hood wanted Triumph 7
T TR2/3/3A TR3 Engine Noise trouble. New to Triumphs. Granfather's Car. Need Help. Triumph 43
Kleykamp TR2/3/3A TR3 lower engine parts?? Triumph 2
Got_All_4 TR2/3/3A Tr3 engine trany pull Triumph 6
Brinkerhoff TR2/3/3A TR3 free engine parts to forum members Triumph 6
K TR2/3/3A Putting an XKE engine in a TR3? Triumph 10
Kleykamp TR2/3/3A TR4 engine into TR3 crankcase vent tube? Triumph 16
RedTR3 TR2/3/3A Tips for Breaking in a Rebuilt TR3 Engine Triumph 6
charleyf TR2/3/3A tr6 OD tranny on a TR3 engine Triumph 7
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
mt10flyer TR2/3/3A 1959 TR3 engine rebuild problems Triumph 14
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
T TR2/3/3A having no shame I ask another question about a TR3 engine that is giving me fits Triumph 10
DornTRoriginal TR2/3/3A TR3 Engine Painting Triumph 8
5 TR2/3/3A TR3 engine building tips needed Triumph 5
AEW TR2/3/3A TR3 engine front cover repair Triumph 10
D TR2/3/3A tr3 engine Triumph 6
H TR2/3/3A Cant get my Tr3 engine to start. any advice? Triumph 29
V TR2/3/3A TR3 Engine Noise Triumph 33
NutmegCT TR2/3/3A TR3 engine question Triumph 6
MGTF1250Dave TR2/3/3A Questions about Breaking in a refreshed TR3 Engine Triumph 13
MGTF1250Dave TR2/3/3A TR3 Engine Rebuilt & Installed Triumph 7
O TR2/3/3A TR3 Engine Miss Part 2 Triumph 11
O TR2/3/3A TR3 Engine Miss Triumph 5
K TR2/3/3A TR3 Engine block marking? Triumph 4
G TR2/3/3A TR3 Rear engine seal issue Triumph 13
T TR2/3/3A TR3 engine ground Triumph 9
O TR2/3/3A TR3 engine removal Triumph 5
Bremer TR2/3/3A Hypothetical: Big bore TR3/4 engine Triumph 13
MGTF1250Dave TR2/3/3A TR3 Engine Noise Identified Triumph 11
PatGalvin TR2/3/3A Engine Harness and/or Attachment Points for TR3 Triumph 10
MGTF1250Dave TR2/3/3A TR3 Engine Noise Up-date Triumph 11
C TR2/3/3A tr3 engine numbers Triumph 23
MGTF1250Dave TR2/3/3A TR3 Engine Hoisting Fittings Triumph 5
MGTF1250Dave TR2/3/3A TR3 Engine Noise Triumph 26
T TR2/3/3A TR3 floor replacement. Engine in or out? Triumph 3
K TR2/3/3A TR3@70mph engine seemed to "flatten out" or..... Triumph 10
A TR2/3/3A TR3 engine removal Triumph 9
GBRandy TR2/3/3A TR3 Engine Bay Color Triumph 5
