TR4/4A Bent Valves
KVH
I'm replacing a bad cam. Two bad lobes. Two bad lifters. But, now, my machine shop says 6 of my 8 valves are pounded and slightly bent. What would cause that? My pistons look good. Car ran great. My valve seats/guides were replaced 15,000 miles ago at most. thx
CJD
I would think he means "warped". Warped valves happen with use and age and is common. "Bent" valves are from mechanical damage, which it doesn't sound like you would have. Not sure what "pounded" is referring to. Either the tips are mushroomed from the rockers or the seats are worn down?? The more expensive valves have the hardened stelite tips, to prevent mushrooming over time. Many of the cheaper replacements do not.
What's the story on the last cam rebuild? What was done and for what reason?
gbtr6
Possible the engine overheated badly? If so, the valves could have seized in the guide, and that would cause the cam, follower and pushrod damage.After cooling, the valves would again move in the guides. I know because I had that on my 6.
Perry
KVH
KVH
I need help on this one. My shop is puzzled. Old receipts show a good, professional head job, new valves, including Stellite exhaust valves, new pushrods and the supposedly uprated lifters and new springs. The pistons don't look like they got hit. But 6 valves are bent, including all four exhaust valves. What happened?
My cam was "probably" a performance cam, but I can't find that receipt. The car overheated badly twice, but I just can't imagine that was the problem. I shut down quickly both times.
I've had pre-ignition in the past (not in the last year or so), but I always use the clutch to shut down and only rarely did a have "run-on" for more than two seconds at most.
Ideas?
CJD
Who installed the head?
I ask because the last time I bent a valve it's because I bumped into my fresh head that was standing up on edge on the floor. It looked great, but valve started sticking immediately on fire up. Only then did it occur to me that I cause the bend. Also curious why you pulled the head if it was running great?
The time before that I had piston contact. In that case the valve didn't just bend...it broke off the head after about 200 miels of driving. Ran great until it swallowed the valve!
I guess my point is...a bent valve is always mechanical damage. Something hit your valves to bend them.
Rut
Are the valve guides cast iron or bronze? If bronze they need just a touch more room than the cast iron guides when they are reamed or they can seize. This is pretty common in other LBCs as well.
Rut
AltaKnight
I'd be suspicious of the newly installed performance cam; the excess lift on some cams can case all sorts of geometry problems with the valve gear (particularly if that is stock) and valve springs (coil bind) which "could" result in bent pushrods and/or valve stems.
bobhustead
Like CJD, I wonder what is meant by bent. Valves depend on contact with the seat for cooling. Too little lash or excessive degrees open will add to heat.
KVH
KVH
They are saying they don't want to grind the valves because they won't spin correctly. I'm no expert on how it's done, but they're saying the valve faces wobble like a crooked spinning top, mainly the exhaust valves. I suppose it all might relate to heat. What is "lash"? Is that the .010 tappet clearance, or something else?
PS It ran great, like a champ. But I was getting a clicking sound off Piston 3 and figured it was a bad tappet. It was actually a bad cam and tappet, and likely my fault since I never did a "cam breakin" after a rebuild with a new cam installed. That's why I pulled the head.
bobhustead
Lash is the adjustment clearance as you suggest. To me, the wobbly head suggest heat damage. Doesn't take much, these being thin wafers, and you said above you overheated significantly a couple of times. BTW, when you shut down a hot engine the temps of the iron go up for a while because the coolant is not dissipating the heat.
Webb Sledge Bent Valves/Head Gasket? Triumph 13
B Bent frame rails near BE front end Spridgets 2
P Classic Tube Pre-Bent Brake Lines Austin Healey 5
PAUL161 T-Series Bent Push Rods MG 34
L TR2/3/3A Bent lower wishbone arms Triumph 6
C TR4/4A Bent pushrod Triumph 20
M TR2/3/3A Forward Carb Jet Lever Bent Triumph 12
B Overdrive Operating valve bent Austin Healey 15
J Healey 100 -- Broken rocker and bent push rods !!! Austin Healey 7
N Spitfire Should this be bent? Triumph 4
nevets pre-bent brake lines Austin Healey 7
M Bent Frame Spridgets 3
B TR2/3/3A is this a bent tr3b frame? Triumph 7
tinman58 Bent pushrods Triumph 69
J Disc rims all bent and out of round Triumph 11
bugedd My bugeye is bent Spridgets 31
jsfbond Flange bent? Triumph 6
glemon Bent Rear Hub/Axle Triumph 2
theleisure 3 out of 4 wheels bent, looking for new used set Spridgets 11
H TR2/3/3A TR3 Accelerator Shaft -- Straight or Bent? Triumph 9
I TR6 TR6 windshield frame bent? Triumph 8
19_again coil springs are bent Triumph 10
R How do you tell if a rim is bent or warped Spridgets 1
J Bent camshaft for 64 BJ8? Austin Healey 1
K Bent trunnion fulcrum Triumph 21
G Bent a Lifting Eye.....Whew! Triumph 8
69MGC Any tips for fixing a bent boot lid MG 7
drooartz Bent pedestal stud Spridgets 13
pan Bent push rod Austin Healey 3
sultanoswing Bent Rims - fixable? MG 10
timbn2 Bent BN2 Steering Column Austin Healey 8
gsalt57tr3 TR2/3/3A TR3 Bent Frame Triumph 13
Webb Sledge TR6 TR6 Throttle Linkage Bent? Triumph 5
AUSMHLY bent frame Austin Healey 15
Guinn Bent bonnet MG 5
S TR4/4A Bent TR4 Frame Triumph 5
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T TR2/3/3A cylinder head ,valves and springs Triumph 0
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
S TR6 Stromberg Bypass Valves - Question Triumph 11
B TR4/4A Oversize valves Triumph 3
D Grose valves / Tri-carb Austin Healey 11
N Floats and needle valves Austin Healey 14
S TR2/3/3A Valves question Triumph 9
steveg PCV Valves - testing Austin Healey 8
HighAltitudeTR3 TR2/3/3A I have a tick, or maybe a slight tock... valves? Springs? What? Triumph 11
KVH TR4/4A Valves and Guides Triumph 10
Csarneson BN4 Longbridge Oversized Valves? Austin Healey 5
Rut Lapping valves Spridgets 5
S Float valves for HD8 - Grose Type Austin Healey 20
