RJS
Hi
Late last season (2011) my water pump starting howling. It started as a noise, quickly became a groan and got to the point where it was howling pretty good. You could hear it over the engine and road noise when driving at speed. It really sounded quite bad. It was the end of the season so, I put very few miles on it in this condition. It was not leaking.
So, after storing the car for the season, I did my research and was all ready to install a new water pump this spring as part of my bi-annual cooling system flush.
Well, just two weeks before I did this, I came across a thread on an Alfa forum where the author said he had used Water Wetter, experienced a water pump noise and resolved it by flushing out the cooling system and refill with 50/50 water and anti-freeze. This got my attention since I had added Water Wetter for the first time at my last flush in July 2010 (about 1,000 miles ago).
My feeling was that I had nothing to loose. So, I did a full flush and refill. Low and behold, my water pump is now significantly quieter. It still makes "some" noise but, you have to pop the hood and really listen for it. And, for all I know, it did that before.
I can't really explain it but, it works for me. I'll let you know as I drive more this summer whether the sound goes away completely, stays the same or gets worse again. In the meantime, water pump replacement is on indefinite hold
Bob
Bob
