TR2/3/3A Replacement or rebuild kit for water pump
bobhustead
I got a new Moss water pump. OEM pump shaft and pulley are slotted at .125. The new pump has a metric slot and key. OEM slot is .125 and OEM key is slightly less than .126. New metric key is .018. ANSI specifies key width from +.001 to .000 in relation to the key slot. Moss is working on this, but meantime I need a water pump compatible with my OEM pulley. Does anyone have recent experience with another vendor?
Thanks, Bob
TR3driver
Great Pumpkin - R.I.P
Not too recent, but the pump & pulley I got from TRF a few years back seemed to fit and work fine. No problems yet.
I did notice some noise while changing coolant yesterday, but it turned out to be a belt that was about to go. New belt solved the problem.
But I didn't check the fit of the key particularly. I know it's important for the pulley to be a tight fit on the shaft (and to be careful when driving it on so the impact doesn't get transferred to the bearings); but as long as it's tight on the shaft I don't see where clearance to the key would be an issue. Unlike some keyed drives, the force is always in the same direction.
B
bobhustead
Given that the taper is not an interference fit, I fear that inertia will cause the key to slowly abrade the slot in the pulley. I will talk to my machinist about cutting a 1/8 slot in the shaft or regrooving the pulley to the metric dimension.
Bob
TR3driver
What taper? AFAIK it's a straight shaft, and should be a light interference fit. If not, the wiggling action (from the sheave being so far away from the mounting surface) will tear up the joint no matter how tight the key is.
Geo Hahn
...I will talk to my machinist about cutting a 1/8 slot in the shaft or regrooving the pulley to the metric dimension.
If you're willing to involve a machinist perhaps they could just cut down the upper half of the metric key to be .125" -- shouldn't have to do that of course but then the modified key would fit both parts (shaft & pulley). I would be reluctant to modify the pulley.
B
bobhustead
The metric key is thinner and its arc of a much smaller radius than the OEM key. Thus any machining would need to be of the bottom of the OEM key and leave little depth of penetration by that key into the shaft.
martx-5
B
bobhustead
My micrometer agrees with Randall on the lack of shaft taper. I had thought a slight taper because they don't start to tighten up until the pulley is slid almost all the way on. The fact that it is straight makes me more dedicated to proper fit. Decided to buy the Moss replacement pulley, so I called to check dimensions. They tell me the slot is 1/8. So much for that idea.
Bob
B
bobhustead
One millimeter = about .0394, so the metric key is 3mm. Machinist can recut the key pocket one of 3 ways without even removing the shaft from the housing. Sorry for the typo. .118 is the number
Bob
SteveBones
Not the answer you are looking for but wanted to share. I did recently....one month ago.....replace the water pump on my TR3A. I purchased the moss water pump. I also purchased a new pulley. I know the pulley was not free, but not too expensive. If you are considering this route, just wanted to let you know the new water pump and pulley from moss did fit.
R BT7 engine gallery plug replacement during rebuild Austin Healey 3
Timd Front end rebuild + A-arm replacement alternative Spridgets 6
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
WHT Rocker Arm Shaft Replacement Austin Healey 21
Celtic 77 MGB Seat webbing replacement. MG 1
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Celtic 77 MGB Seat Diaphragm replacement MG 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
K TR2/3/3A Wing mirror replacement again... Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
B T-Series Battery replacement mgtd MG 2
F TR4/4A Speedometer cable replacement access Triumph 0
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
T TR2/3/3A Replacement radiators Triumph 8
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
F TR4/4A Replacement air filter for SU HS6 Triumph 6
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
A MGB MGB 1974 windscreen centre rod replacement MG 5
B Poor quality BE replacement spring boxes Spridgets 0
AUSMHLY BJ8 Laygear Replacement Options Austin Healey 0
B TR6 Fuel tank replacement Triumph 0
S MGB clutch replacement MG 7
S Wiring Harness Replacement Spridgets 1
JPSmit Not something you see everyday - a warranty replacement Spridgets 1
M 1972 Midget Seat Belt Replacement Spridgets 4
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
T TR2/3/3A tr3 front carpet replacement Triumph 5
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
D Engine replacement. Rover / Land Rover 0
EWD TR6 Dash Pad Replacement Triumph 3
R TR6 fan shroud replacement Triumph 5
C Replacement wheels Rover / Land Rover 1
B TR4/4A Floor pan replacement Triumph 4
DrEntropy MGB Replacement starter MG 7
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
P TR6 1970 TR6 Passenger Sun Visor Replacement Triumph 1
M General MG Midget MK1 windshield replacement MG 2
M TR6 Replacement Steering Rack ? Triumph 7
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
A TR2/3/3A TR3-A replacement top Triumph 7
C TR2/3/3A Horn Control replacement Triumph 3
nichola TR6 Transmission front seal replacement question Triumph 8
J BN2 Shift Lever Bushing Replacement Austin Healey 6
L 100/6 replacement front seats Austin Healey 7
