TR4/4A Does the water pump need to come off to remove the cylinder head?
tdskip
You would think I'd know this at this point, but the manual isn't clear (to my eyes anyway since it only references that as a part of a full tear down).
Thanks, and hope everyone us having a good weekend.
titanic
I usually just unbolt the water pump housing (which includes the water pump) from the head. Also, the the pipe that attaches to the water pump housing has to be loosened.
Berry
Merlin63Tr4
No, the water pump housing is not attached to the cylinder head it is attached to the cyl block.
But since the heater pipe is "kind of in the way" and it only takes a few minutes to remove the WP housing with the heater pipe and water pump attached, I usually remove it for clear access to the head/cyl block interface for cleaning, etc.
M.
Geo Hahn
I leave the water pump in place and also the heater pipe. I do remove the coil and then pull the heater pipe away from the block a bit (wedge or bungee) to get a bit of clearance on that side of the head.
R water pump small hole does line up Austin Healey 7
GTP1960 General Tech Water Wetter, does it work? Triumph 24
AUSMHLY Heater box - how does water get in it ? Austin Healey 32
Musicman Water Wetter - Does this stuff really work? Triumph 18
L What does this column switch do? Spridgets 4
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
J MGB HELP, my horn does not work! MG 8
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
S TR2/3/3A overdrive does not function Triumph 45
Bayless How does '67 Sprite top attach to body? Spridgets 3
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
B General MG Does odometer record when flat towing. MG 5
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
T Does a car lift exist that could be placed against a wall, and the car rolled sideways onto it? Spridgets 16
TomMull TR2/3/3A rear mount does not line up Triumph 10
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
JPSmit Fuel tank sender - how does it work? Spridgets 4
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
NutmegCT Does this ad seem a bit peculiar? Other Cars 8
S TR2/3/3A What does a condenser do? Triumph 21
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
D Does this count as British car? Spotted 18
BN6_2197 How does the flasher unit work Austin Healey 4
J TR6 Does this sound ok to you? Triumph 5
BN6_2197 Analyzing Problem of Flasher Unit [warning lamp does not work] Austin Healey 10
B Does anyone still make or sell a quality condenser? Austin Healey 14
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
T TR2/3/3A Does this sound like fuel pump problem? Triumph 15
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
F How does overdrive Annulus effect speedometer Austin Healey 10
T General Tech Transmission Countershaft - What Car Does This Fit? Triumph 1
D Does a BJ 8 need a vented fuel cap? Austin Healey 4
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
B MGA What does this founder mark mean? MG 4
D TR2/3/3A Gas tank does not fit! Triumph 4
Got_All_4 TR6 How does this steering lock come off Triumph 9
Gerry M TR6 Overdrive does not engage Triumph 13
HighAltitudeTR3 TR2/3/3A How does this sound?! [Video] Triumph 8
C TR6 ZS 175 What does this screw do? Triumph 2
HealeyRick Who Knew Martin Jansen Does Bikes? Austin Healey 0
Rut How much does a 1275 weigh? Spridgets 8
JPSmit Fuek Tank Sender - does this seem right to you? Spridgets 3
HighAltitudeTR3 TR2/3/3A How does this sound?? Triumph 6
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
D TR4/4A how hot does the timimg chain cover get? Triumph 15
D TR4/4A Does a bolt legend exist? Triumph 3
Rut How does this happen? Spridgets 9
