Hi all,
Actually, this procedure is noted right in some of the Triumph factory service manuals.
You can either spin the pump dry for a minute or two with an electric drill before installing it, or wait until installed and run the engine briefly (30 sec. to 1 minute) without topping up the coolant level. This was done to seat the ceramic seal used in the older pumps. If this wasn't done, the coolant were topped up completely right away, it would prevent the seal properly forming and the pump would always seep a little coolant.
HOWEVER, I don't for certain know that a pump with this type seal was ever used in the 6-cyl. engined cars (TR250/5/6) AND I would be willing to bet all new pumps today (including rebuilds) use a more modern type seal that doesn't require this sort of break-in procedure.
Ask the vendor who sold you the pump, just to be sure. The last pump I bought (for TR4, new, high performance type with 6 curved impellor blades) came from British Frame and Engine and Ken Gillanders confirmed no break-in procedure was required. Can't speak to the other vendors, but I would gamble that VB's info is seriously out of date.
