valve / rocker cover
weewillie
will this be ok on my '72 midget.It is stamped inside with jvm england cam6822
gchase
Looks to me like it would be better off on a Mini block.
Seems to me I had seen one like that before - with the transverse engine it looked good.I guess it all depends on how it looks to you when mounted. It should be the same size - give it a try - stand back and look.
If you like it , great. At least it will be unique.
Go for it.
dklawson
It does look like a Mini valve cover but certainly will work for your inline engine.
JerryB
The slanted cover that U have was used on Minis quite a bit and also were used on many Formula Jr.'s as it allowed lower body lines.
Fits all A motors and is certainly 60's period looking.
leecreek
Mine is sitting in the shop waiting on a little clearancing to clear the roller rockers. Pretty unit tho.
JerryB
"""""""on a little clearancing to clear the roller rockers. """""
1.5: Titans will clear with a thicker v.c. gasket but not if they are offset more than about .030" to the pushrod side.
The 1.5 Sharps are offset a lot more and will no way clear even with major mill surgery.
The cheapie Moss die cast piece clears all. Certainly not designed that way...just .02thin by coincidence.
S MGB-GT Wanted: REMCO MG Rocker/Valve Cover MG 0
S A few valve cover [rocker cover] related questions, 3000, BJ8. Austin Healey 9
P Valve/Rocker cover Austin Healey 5
S TR2/3/3A All new valve train - no adjustment at rocker arms Triumph 12
J Rocker valve assembly picture Austin Healey 6
S TR6 Help! Need help from TR experts with this frustrating TR6 pushrod/rocker/valve issue Triumph 23
chrpark disassembling/cleaning valve rocker train Spridgets 5
Brosky Roller rocker arms and valve seals - ideas? Triumph 30
PAUL161 Rocker Arm / Valve Clearance -Hot or Cold MG 0
D TR4/4A TR4 valve & rocker lubrication Triumph 5
X setting valve /rocker clearance MG 17
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ‘74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
K TR2/3/3A Brake Restrictor valve? Triumph 9
Lin Heater water valve question Spridgets 2
D MGB MBG valve clearance MG 1
