Valve adjustment help.
JoeBeets
I'd like to adjust the valves on my 61 TR-3, but I'm not sure how to tell when the cylinder I'm working on is at the proper position. Also, can't find a timing mark anywhere, so timing wise, we're just guessing. The car runs very well,so I think close, but I'd like to be sure. Thanks for any ideas.
Eric
Just watch the rocker arms on the valves. You'll be able to see when the rocker starts to move the valve down and when it ceases to push on the valve. TDC is mid way between.
Bugeye58
Just use the old "Rule of Nines". When #1 is all the way open, adjust #8. (1+8=9) When #3 is open all the way, do #6, etc.
So simple even I can remember it!
Jeff
waltesefalcon
Ok here is the way I have always done it. With all the spark plugs out and the valve cover off Turn the motor over till you get the cylinder you want at the top of its stoke. Then just check to make sure both your intake and exhaust are closed, i.e. the rocker arms both have slack. If so you are at TDC and can set your valves on that cylinder. If you have pressure on the exhaust then turn the motor over a full revolution and you will be at TDC. The trick to this method is making sure you have the cylinder at the very top of its stroke, and not a little before or after.
TRMark
Bronze
I have used the rule of 9's for about 30 years; very simple way of getting it done. Got it from the Competition Preparation Manual by Kastner. You can take his advice.
I Valve adjustment basics - help please Spridgets 21
I TR6 TR6 valve adjustment help Triumph 3
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
G Valve adjustment and easiest way set cam position Austin Healey 15
S TR2/3/3A All new valve train - no adjustment at rocker arms Triumph 12
K TR2/3/3A Valve Adjustment? Triumph 17
L TR6 Bypass valve adjustment Triumph 1
wangdango BJ8 valve adjustment? Austin Healey 3
Martinld123 Why too much valve clearance after adjustment? Austin Healey 2
Boggsy64 MGB Valve adjustment MG 6
Darwin GT6 GT6 Valve adjustment Triumph 6
nevets Valve adjustment intervals? Austin Healey 15
6 Valve adjustment stock 948 Spridgets 11
glemon Valve Adjustment/Wear Triumph 4
Rut 1275 valve adjustment Spridgets 10
Rut timing, cams, valve adjustment Spridgets 6
BOBBYR VALVE ADJUSTMENT Austin Healey 1
G MGB MGB valve adjustment MG 3
M 1275 valve lash adjustment "shade tree" Spridgets 10
Marvin Gruber Valve adjustment Part 2 Jaguar 11
Marvin Gruber Valve adjustment Jaguar 15
M valve adjustment? Triumph 5
Woodie valve adjustment Spridgets 5
66healey Valve adjustment Austin Healey 11
newmexTR3 valve adjustment q's Triumph 4
T Valve adjustment 'how-to- on YouTube? Triumph 3
R Valve Adjustment Question Austin Healey 12
malice Valve Adjustment Triumph 2
TRclassic3 TR2/3/3A TR3 Valve Adjustment Triumph 10
H Valve adjustment question MG 10
M TRactor Motor Valve Adjustment Sequence Triumph 5
sparkydave How sensitive is the valve adjustment? Spridgets 11
B valve adjustment Austin Healey 7
R Valve adjustment Austin Healey 6
S Valve Clearance Adjustment Austin Healey 17
M Valve adjustment MG 12
tahoe healey valve adjustment Austin Healey 14
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
