Ray,
Here is a previous discussion on the subject:
https://www.britishcarforum.com/ubbthread...=true#Post88202
To add a bit.
The BN1, BN2's had no tags but the shop manual recommended .012 cold.
The 100M cam recommended .015 cold.
The BN4, BN6, BN7, & BT7 had a riveted brass plate which had .012 hot.
The BT7 & early BJ8 had a riveted brass plate that said .012 hot.
The later BJ8's had an aluminum riveted tag that said .012 cold.
The last BJ8's had a stick on foil label that said .012 cold.
In reality, there is very little difference in gap between hot & cold. It actually won't make much difference which of the clearances you use as long as they are accurately & uniformly set. I personally would use .012 cold. If using an aftermarket cam, use the makers suggested clearances.
