I reset the valves after the first 500 miles or so on my rebuilt motor recently. I have read a lot about valve recession, and I thought with a rebuilt head everything might settle in a little bit and I would have tight clearances. To my surprise none were tight, about a third were still in spec, and the rest had a little to a lot too much clearance. I did not measure, but some were pretty lose, I tightened them all up, the engine sounds better now (less valve clatter).
But it got me curious, I understand what would close the gap, but what would make the gap bigger, only thing I can think of is wear to the rocker shaft or the valve stem ends or rocker ends, but I wouldn't think that would amount to much over 500 miles. I am not that worried, but just curious about opinions, is this more or less normal, and what would the typical cause be?
Thanks Greg
Thanks Greg
