U.S. source to repair or replace Smith's gauge
ming11
Nisonger, the Smith's U.S. rep. does not have the parts. The gauge is for a 1948 Jaguar 3.5 Liter Saloon. It is model# X.49422/67.
AweMan
Re: U.S. source to repair or replace Smith's gauge
Here is another that deals with Smiths Insturments
https://www.gaugeguys.com/
eschneider
we use John Wolf 440-942-0083.
warning - he is expensive AND slow (3-9 month turnaround, regardless of what he tells you)
but he is the BEST with smith gauges. His work is impeccable. I use nobody else, but I expect at least a 6 month wait. If he does it 3, great.
Administrator
Boss
Well, that would have been my first recommendation! YOu might also try emailing David Beals in UK at d.beales@ntlworld.com He is an old Daimler expert but may be of help.
1965_MGB
I have a friend with an E type that had a fried speedo. He sent it to the gauge guys mentioned above. He tells me the price was fair, and the turn around time was good. He would not get more specific than that, but he is a cagey guy anyway.
AweMan
The Guage Guys quoted me a little more for repair of my temp guage than Nisonger did, BUT the Guage Guys turn around time was MUCH shorter. Can you wait? If so go with Nisonger there a little cheaper {at least for my temp guage they were} If you can`t wait go with the Guage Guys or someone else.
I got my M.C. {Dual Master Cylinder} back from Apple today @ $217.00 looks like new, good turn around time, {about 14 days} 7 of which were my fault for choosing the U.P.S. ground frieght. All in all I`m happy with the results.
Platinum
I've used Nisonger for years. Reliable, thorough and right the first time.
Apple has done many sleeves for us, as has White Post. Lots of old Rolls cylinders. I'd likely use Apple for any of my own cars.
Brosky Excellent source for Lucas alternator repair Triumph 0
R TR6 Help: Brake Part Source or …. ? Triumph 1
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
Jayplum TR2/3/3A Source for quality parts Triumph 11
B Vacuum Source Austin Healey 4
W Best source for Bugeye front shocks Spridgets 3
B TR6 Source for Carmine Red Triumph 4
steveg TR6 Source for fuel line P-clip Triumph 17
Sarastro TR4/4A Source for good convertible-top snaps Triumph 6
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Michael Oritt Tenax fastener source needed Austin Healey 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
R TR6 Body Parts Source, Upper Midwest Triumph 6
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
S TR2/3/3A source for those little drain hoses Triumph 6
I TR6 Source for Elevator Bolts? Triumph 16
I TR6 Source for license plate light bracket? Triumph 5
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
MikeAH100M Whitworth Source Austin Healey 8
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
K Healey Blue Paint Source Austin Healey 30
D Body work finishing supplies source. Restoration & Tools 0
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
JPSmit DC Power source thoughts Restoration & Tools 11
B TR2/3/3A Locating source of oil leak Triumph 6
J Half round tube or D tube source ?? Restoration & Tools 2
HealeyDave TR2/3/3A TR3 Dash Cover Source Triumph 9
B New frame candidate or parts source? Austin Healey 12
S Bay Area source for 60 Sprite Roll Bar? Spridgets 6
Jim_Gruber Source for PosiDrive Screws Spridgets 7
R TR2/3/3A Source for rubber seal on A/M side curtains Triumph 4
J TR4/4A TR4A rear wheel cylinder source Triumph 3
I Bigeye transmission source? Spridgets 7
Rut TR4/4A Good interior source Triumph 29
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
Jim_Gruber Source for Small U Bolts on 1/4 Elliptic Springs- Spridgets 11
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
Csarneson Source for BN4 2nd Gear Austin Healey 8
CJD TR2/3/3A Source for Horsehair Padding? Triumph 10
Michael Oritt Rear upright casting--source needed Racing 4
I TR6 Under bonnet sticker source Triumph 3
D General TR Front carpet source? Triumph 1
Steve P. Best source for new tappets? Austin Healey 11
I General TR Source for glass mirrors Triumph 5
