Ahead of all the other things, as I mentioned before you should check the accelerator pump jets for blockage. It's not uncommon for them to have build-up from ethanol fuel mix if they sit for periods of time without having fuel run through them. The jet holes are SMALL and difficult to clean easily, too. But at least they're easily accessible without having to tear into the carb bodies.
Summit Racing and Red Line also have Weber bits.
