Ok, after finishing the front suspension, I took the car out for a drive. After about 15 minutes, I start to smell smoke and see smoke coming out of the left side of the bonnet - I figure some wire smoke and pull over to check...
Indicators and horn don't work, so I reckon its that fuse system. After limping slowly home (no more smoke) and noticing that the red ignition warning light is on and the volt-meter is showing a slow decrease, I decided it could be an alternator problem. The indicators and horn work again after re-seating the fuse (it didn't blow), although the indicators don't flash, just stay constantly lit - maybe the flasher unit. The alternator belt was pretty shot, and came off on testing at home.
So, I've just been to AutoZone to get a new fan belt (and fire extinguisher!). They sold me a Duralast cogged V-Belt (part # 15445) which is 1.1 cm wide and 1.1 m long. After fitting the new belt and tightening it so there is around 0.85-0.9" play, I start the car....now I have the following symptoms: squealing (I guess indicates that the fan belt is loose) and a burning smell plus a lot of smoke. I'm 95% certain that the smoke is from the belt and not the alternator - it also comes from the other pulley areas. So - did I get sold the wrong belt? Is it too loose? Can anyone recommend a good off-the-shelf belt?
FYI I have a 1976 non-PI TR6 with a Lucas alternator and looking for the alternator-water pump belt.
Thanks,
Mark
Thanks,
Mark
