TR4/4A TR4 gear shift knob
TR4nut
Larry-
I saw one in England not long ago, and think I may be able to source another possibly. PM me if interested, and let me know what price limit you have. Happy to courier it back for you, it would make it back around end of June if I found one.
Randy
PeterK
I bought one from Moss a few years ago, noticed now it's NLA. I also see them attached to gearshift levers on ebay once in a while.
ISTR that an early 60s corvette uses the same knob so add this to your ebay search, but check the thread size to be sure.
toysrrus
Hi There Larry;
I have one in My "Glove Box" (Not For Sale): The Dia. of the Knob is so Small; Its a really Strange Feeling driving with It on: To Me, It almost feels as though your going thru the Gears just with the Gearshift Lever & No Knob:
I drive with a Wooden TR Knob & When @ Shows, Just put the Orig. on "For Show, Not for Go"!
What did the TRF Charge Yourself?
Regards, Russ
G
The black plastic teardrop-shaped gearshift knob with the shift pattern cut in white on the top had a nice, warm feel to the palm of my hand.
toysrrus
Hi Folks;
The Orig Gear Shift knob for a "TR3" is a Teardrop Style with the Shift Pattern in White:
The Orig Gear Shift knob for a "TR4" is about the size of a Golf Ball (Less Dimples, Your Right Tomster)! Its Black with "No Pattern"!
Hey Larry; Which one did you buy for your TR4??
Hope Its Round;
Regards, Russ
PeterK
toysrrus said:
Hi Folks;
My TR3A shift knob is upside-down pear shaped hard molded rubber with a raised gearshift pattern but in black, no white on the pattern. Maybe it wore off?n Supposed to have a chrome locknut but none on my car.
And my 4A knob is about the size of a billiards ball, larger than a golf ball, hard black plastic, unmarked.
toysrrus
Hi There Larry;
I was just driving thru & was curious as to What kind of Gearshift You Rec`d. from TRF??
Regards, Russ
O TR4/4A tr4 pops out of second gear on deceleration Triumph 13
T TR4/4A Has anyone used steel gear bushings in their TR4 transmission? Triumph 3
A TR4/4A TR4 Slips out of 3rd gear Triumph 5
KVH TR4/4A TR4 Timing and Distributor Gear Triumph 3
Tinkerman TR4/4A Cluster gear removal TR4 syncro box Triumph 2
A TR4/4A TR4 gear box question Triumph 4
A TR4/4A TR4 gear box oil Triumph 13
A TR4/4A Converting TR4 gear box to O/D Triumph 4
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
