TR2/3/3A TR3 Seat Belts
Wmhutson
I need to install seat belts into my TR3 (otherwise my wife won't ride in it). My preference are 3 point belts. Any guidance on what belts to buy and how to install?
I have seen the third point added to the convertible top sticks with a long screw. Suggest a jamb
nut to hold the adjustments of the top.......
Mad dog
Use provided anchors for lap portion. I attached tag end of shoulder belt through rear fender well supplemented by VERY BIG flat washers inside and out. Top frame bolts are 1/4 x 20 and not suitable for the anticipated load.
Bob
Bob , I hate to break it to you there is ZERO strength in a Tr3 upper cockpit. So any anticipated
load is too much regardless of where it is attached. Also NO door intrusion beams ect.
Mad dog
Then...so long as your car doesn't roll over or your steering column impale you...you are securely held in! Sorry to be graphic, but although I did add seatbelts to TR's previously, I decided against them on my current TR2. The chance of a front end collision or roll-over is better than 50/50, so I look at driving the TR as being closer to driving a motorcycle than a real car. Adding a roll bar would change that equation, making seat belts a solid positive addition!
When I was looking to add seat belts to my TR3B many years ago, I found a article that said that shoulder straps should not be mounted below your shoulder because in an accident the belt would tend to compress your spine and cause more damage. I went with just belts.
Thanks for everyone's feedback on this. I figured that if a collision were significant enough or the car rolled over a seat belt or 3 point would not save me from death anyhow. As one writer pointed out, a TR3 isn't much safer than a motorcycle. Seat belts are in and my wife enjoys the ride all while appreciating the risk.
I actually rate the motorcycle safer! You sit higher, are more maneuverable, and see better.
When these cars were new and we were 19 or 20 years old, we had no fear of getting injured, however, you would be better off getting thrown out in a rollover. As mentioned above fitting a roll cage is the only way you would want to be strapped in otherwise you would get ground down to about waist height, I hope I haven't put you off seat belts.
Graham
I suggest in modern traffic to "pretend" you are a motorcycle , invisible to most of the idiots.
Anticipate their next stupid maneuver , and stay clear. I have personally seen a driver hit a firetruck
WITH lights and sirens ,60 feet long ,fluorescent green. One can only surmise he would have never seen
a Triumph
Mad dog
A TR2/3/3A Tr3 Seat Belts Triumph 3
B 60 TR3 Seat Belts Restoration & Tools 0
R TR2/3/3A TR3 seat belts Triumph 7
martx-5 TR2/3/3A Seat Belts in TR3 Triumph 41
J TR2/3/3A TR3 Rear seat Triumph 11
B Wanted TR3 seat frames repairable Triumph Classifieds 1
T Wanted TR3 Seat Frames and Seat Rails Triumph Classifieds 3
tr3guy TR2/3/3A New TR3 Seat Rail Glides Triumph 3
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
T TR2/3/3A TR3 Seat Questions Triumph 10
M TR2/3/3A 1956 TR3 ocasional seat Triumph 10
Tinkerman TR2/3/3A 1960 tr3 a seat tack strips Triumph 19
luke44 TR2/3/3A TR3 Which Seat flips? Triumph 11
B TR3 seat frame issue Restoration & Tools 2
J TR2/3/3A TR3 seat patterns Triumph 9
M TR2/3/3A TR3 seat rebuild Foam VS Springs Triumph 7
mountainman TR2/3/3A TR3 Rear Seat Triumph 3
mountainman TR2/3/3A TR3 Back Seat Support Brackets Triumph 3
E TR2/3/3A TR3 seat track width Triumph 10
M TR2/3/3A TR3 Seat Rails Triumph 10
MGTF1250Dave TR2/3/3A TR3 Optional Rear Seat Triumph 22
CCURTISS Removing Seat Track Screws TR3 Restoration & Tools 3
PeterK TR2/3/3A TR3 seat rebuilding with foam. Triumph 4
fad64b TR2/3/3A TR3 seat back padding? Triumph 1
AngliaGT TR2/3/3A 3 Seat TR3? Triumph 25
fad64b TR2/3/3A TR3 seat redo Triumph 17
TRclassic3 TR2/3/3A TR3 seat comfort Triumph 3
D TR2/3/3A TR3 seat rebuild Triumph 11
bluemiata90 TR2/3/3A tr3 seat slide rail locations Triumph 3
martx-5 TR2/3/3A Problem with TR3 Seat Triumph 9
R TR2/3/3A TR3 Heater Fan Triumph 8
W TR2/3/3A TR3 dead cylinder ? Triumph 52
G No directional signals or brake lights on 60 Tr3. Triumph 2
T TR2/3/3A Rear Wheel Bearing instillation on TR3 Triumph 11
RichB4493 TR2/3/3A Rare “TR3” spotted on safari Triumph 3
71TR6 For Sale TR3 Radiator with crank hole- refurbished Triumph Classifieds 3
jfarris For Sale Original Style TR3 Luggage Rack Triumph Classifieds 0
jfarris For Sale TR3 early used fan $25 + shipping Triumph Classifieds 1
71TR6 TR2/3/3A TR3 rear axle shims Triumph 7
IdahoNuke For Sale Free TR3 Seats Triumph Classifieds 0
T Wanted Wanted TR3 rust free nut & bolt restoration Triumph Classifieds 13
R TR2/3/3A 1956 tr3 value? Triumph 7
cguild TR2/3/3A TR3 1991cc engine emits black soot from exhaust Triumph 13
D TR2/3/3A Black TR3 Triumph 20
K TR2/3/3A A TR3 plug check left to right 1234...do I lean out front carb a couple of flats?...turn down correct? Triumph 3
K TR2/3/3A The TR3 is up and running again.... Triumph 7
S TR2/3/3A Battery box for a triumph tr3 Triumph 5
J TR2/3/3A TR3 age Triumph 4
G For Sale TR3 original metal air filters Triumph Classifieds 0
G For Sale 1960 TR3 fitted black cover. Triumph Classifieds 0
