As far as Toyota goes, Belts are out. All their new engines have chains.
Ancient Toyota Secret. If a Toyota motor has a belt, it is a non-interference engine. Meaning that the valves don't contact the pistons if the belt breaks. Chain motors are interference. It's cheaper for a manufacturer to produce an engine with a belt, but tighter emissions controls, and the widespread use of variable valve timing has necessitated the use of chains.
You got your wish Jesse.
Steve. There are two marks on the crank pulley, one is a small notch between two of the crank sensor teeth on the rear flange of the pulley. at TDC it's at about 11 o'clock and lines up with the arrow on the engine, The other is on the front face of the pulley. it is a shallow circle on the end of one of the pulley teeth. It's not very easy to see, and it sits about 5 o'clock with the pulley at TDC. That mark is the one that lines up with the mark on the belt. I usually highlight it with a paint pen to make it easy to see. same with the notches on the cam pulleys
