sparkydave
This is probably one of those questions that has probably been asked before, but what is the relationship between timing and how hot the engine runs? I've heard that having the wrong timing can cause the engine to run hot, and I assume under that condition that extra heat translates into lost horsepower, but is this when the timing is too advanced (fires too early) or too retarded (fires too late)? I've been wondering what effect changing the timing on mine would have, since the 75-79 models seem to have a wide range of timing specifications. I've got mine at 12 degrees before, but wondered if there was a more optimal setting that might help it run a little more efficiently.
