Tenex studs / top fasteners
Jeepster
Would anyone have a few pics to show which tenex stud fits where to the body of my recently restored BJ8?
i see the parts supplies sell a variety of types and lengths but I have no idea which goes where?
Keoke
Look at the female recepticals on : The Top,On the boot cover and the tonnue cover they will tell you. I think off the top of my hea the are all use the same threaded male part but not sure
Jeepster
Jeepster
Unfortunately I don't have those items as yet and also the threaded part seems to be available in different lengths? The padded dash top also requires a couple?
Keoke
The padded dash top also requires a couple? These are associated with the tonnue cover.
Keoke
Then it might be more productive to wait until you get them , because after market fasteners and original hardware differ slightly.
But if you are buying aftermarket covers you can get the correct fastener with each order perhaps if you request them.??
A TR2/3/3A TR-3A Windshiedl Tenex Peg Set Threads Triumph 2
J Need tenex and LTD fasterer locations for BJ8 Austin Healey 0
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
K TR6 TR 6 Wheel Studs Triumph 10
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
Bayless How to repair broken vent window studs? Spridgets 1
KVH General Tech ARP Head Studs/Liner Protrusion Triumph 10
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
DrEntropy MGB And now, NO ARP head studs to be found! MG 13
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
Lin Water Pump torque value for nuts on studs Austin Healey 1
M 948 Cylinder Block Studs - Sequence on Cylinder Block Spridgets 4
D TR2/3/3A manifold studs..locktite or antiseize Triumph 5
K For Sale TR3 Hub...short studs Triumph Classifieds 0
D TR2/3/3A More small nuts [ and studs!] Triumph 2
W TR2/3/3A TR3 wheel studs Triumph 4
af3683 TR2/3/3A Distributor Clamping Plate Studs Triumph 15
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
A TR2/3/3A Lift-a-dot studs [for wood] Triumph 5
K TR2/3/3A Longer wheel studs? Triumph 5
B 1500 head studs Spridgets 3
D BT7 head manifold studs Austin Healey 7
Jim_Gruber Replacing Wheel Studs Spridgets 10
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
G rear wheel studs on my 1967 BJ8 Austin Healey 5
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
D TR4/4A wobbly exhaust manifold studs Triumph 17
T TR4/4A Are the ARP head studs worth it? [ducks for cover] Triumph 19
T TR2/3/3A Hood Stick Cover LTD Studs Triumph 4
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
gbtr6 TR6 TR 6 Head Studs, replace? Triumph 3
KVH General Tech Removing Stuck Head Studs from Block Triumph 18
S Wheels & Wheel Studs Spridgets 21
bugedd Wheel studs Spridgets 5
maxwedge5281 1/2 inch wheel studs Austin Healey 8
MikeAH100M BN2 Water Pump Studs Austin Healey 1
alanjohnturner TR4/4A studs for the trailing arms Triumph 10
S TR2/3/3A exhaust manifold with rusted and broke studs Triumph 5
MGTF1250Dave T-Series TF Dash Instrument Panel Studs Size MG 2
drooartz MGB-GT Conversion has started - splines to studs MG 51
alanjohnturner General TR Head-studs, torques and sizes Triumph 2
B Anyone have any of the Tenax studs [I need two] that I can buy o rtrade or have??? Spridgets 2
Jeepster Tenax studs Austin Healey 4
B Rear Hub Extension Studs Austin Healey 22
T Spitfire Spitfire wheel studs Triumph 6
F TR4/4A Knurl hole for TR4A wheel studs... Triumph 18
F New set of lug studs and stripped spines.... Triumph 12
