Teflon tape on hydraulic lines?
Baz
Recommended or not, around the thread on the pipes as they are screwed into the MC's?
tony barnhill
Great Pumpkin - R.I.P
Never found a need to use itthere if the flares are good...
G
Hydraulic lines should be flare fittings. They seal on a flare on the tube not the threads that holds the tube in place. These threads are straight cut, not tapered like NPT. Putting teflon on the threads does nothing but look bad. It the connection leaks look at the flare on the end of the line or in the fitting it screws into for the problem. They should not be over tightened or the flared tubing will crack
Baz
Baz
Just seemed they unscrewed too easily. But then again, I did notice a couple of the pedal box securing bolts were missing (1 under the dash and 1 outboard rear) and my clutch master rod had no clevis pin (nut and bolt instead) so it appears that this has been attacked before in the past.
The flares look good, so I'll take that advice, thank you Tony / Gerry.
G
They should unscrew easily after the first turn or so. If they don't then the threads on one side or the other may be buggered and waiting to fail completely
tony barnhill
Yep, if those things are hard to turn either the threads are bad or theres some gunk in between the pipe & the nut...I always clean my pipes real good before reattaching...I have had them where the nut is frozen to the pipe with rust & crud.
jlaird
The inside of the flair can actually be cleaned up with some fine sand paper, like 600. Only atempt if you have a bit of a leak.
B General Tech Fuel and teflon tape Triumph 10
steveg Teflon tape - another use Austin Healey 1
A Teflon Tape on oil & fuel lines MG 12
G Teflon tape on bleed screws Austin Healey 13
NutmegCT Gasoline resistant sealing tape? Restoration & Tools 3
JPSmit Wire Harness tape question Restoration & Tools 3
NutmegCT amalgamating tape? Restoration & Tools 15
drooartz Off Topic Okay, this is a bit classier than the duct tape MG 4
DanLewis Illuminating gauges with Electroluminescent tape Spridgets 24
Darrell_Walker Rescue Tape -- I like it! Triumph 6
TR6oldtimer Looking for a source for Dry Vinyl Harness tape Triumph 5
T Correct way to tape off unneeded wires Triumph 13
bigjones How to use non-adhesive wiring harness tape Spridgets 2
H Harness Tape MG 1
PatGalvin TR2/3/3A TR3 Leaf Spring Rebuild - low friction tape? Triumph 9
JPSmit Not cars but - Duct Tape! Restoration & Tools 3
G Wire Wheel Question: PVC Tape Triumph 19
lbc_newbie 1275 Midget, Sprite Timing Tape Kit Spridgets 2
martx-5 Cloth Insulation Tape Triumph 4
M SCCA Tom Patton race VHS tape[2001] Sunbeam (Rootes) 1
regularman Masking tape question Spridgets 26
GregW Still got those tape measures handy? Austin Healey 5
GregW Anyone have a tape measure handy? Austin Healey 14
H Geoff Healey @ Encounter 1979 - 8trac tape Austin Healey 9
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
Jim_Stevens TR2/3/3A Clutch slave hydraulic line Triumph 1
TomMull hydraulic fittings "O ring face" Restoration & Tools 6
G TR2/3/3A Hydraulic supply lines from reservoir..replace with flexible Triumph 19
JimLaney hydraulic line material Spridgets 6
J Hydraulic Brake Switch Internals Austin Healey 19
I General TR Hydraulic lift opinions/info needed Triumph 34
C Bleeding the hydraulic clutch Spridgets 6
Lukens TR2/3/3A My theory about my clutch hydraulic problems Triumph 11
Lukens TR2/3/3A Clutch hydraulic problems Triumph 12
M 948 clutch hydraulic line Spridgets 7
W Hydraulic Tank Austin Healey 8
catfood Hydraulic cylinder repair. Restoration & Tools 2
texbears3 TR4/4A Hydraulic Fluid Contamination Triumph 10
DornTRoriginal TR2/3/3A Hydraulic Brake Line Clips Installation Triumph 2
M TR2/3/3A TR3A clutch hydraulic problem Triumph 9
GBRandy Wedge TR8 Hydraulic lifters - Replace? Triumph 1
M TR2/3/3A TR3 clutch hydraulic line routing Triumph 2
Lin 4-post lift hydraulic fluid Austin Healey 5
stretchit2 Hydraulic Shock Fluid - Bilstein Shock Conversion Austin Healey 6
TulsaFred Hydraulic system disassembly-reassembly Spridgets 10
M TR2/3/3A TR3A Hydraulic system problem Triumph 4
Moseso Weird Hydraulic Failure Triumph 8
J TR2/3/3A tr3 hydraulic brake light switch Triumph 13
M Hydraulic Problems Spridgets 5
