Thank you for the kind words.
I am real happy with the way things are going so far. Could not have got this far with out the help, advice and support from the group. Went back and re read CJD's thread before I started on the front wing.
That dog leg patch took several days to get to fit. So if time was money it would have been smarter to have used the phone to order one rather than the hammer. Having just retired I am having a blast working on the TR.
I have jumped to the front wing because the drivers side outer sill does not fit well so I thought that I should get the wing fitted then match the sill to that. The bottom turn under is too short and won't reach the inner sill by about 1/4"? Hand built car or the PO's work.
I removed 2 1/2 pounds of bondo from the wing.
Decided that I should patch the hole first to help stabilize the rear edge of the wing before I attempt to do anything else to it.
David
David
