Starting handles and trafficators...
Sherlock
I had the pleasure of hanging out most of the day at a local car show with the owner of a 1950 Austin A40 Devon (that belongs to a member of our local club).
He took great pleasure all day in demonstrating his use of the starter handle to start the car as well as showing off the trafficators. It brought back good (or bad?) memories for all the old timers, and absolutely astounded some of the younger people who had never seen anything like it before. I for one have never before really seen use of a starting handle, or don't recall seeing the use of trafficators.
We also heard tales all day of early motoring with Austin Devon's, including some incredibly long trips back when the cars were contemporary and the average "highway" in Canada was gravel.
sunbeammadd
My Imp came with its starting handle and I always thought it was really cool having a starting handle that went in the back of the car instead of the front!
Sadly the dog for the handle kept unscrewing itself. I perservered for a while, trying all sorts of things to keep it done up. In the end removed the dog and replaced it with a regular nut as I was afraid of pulleys flying around in the engine bay. /ubbthreads/images/graemlins/frown.gif
aeronca65t
You are mentioning my first "official" car (I "shared" several other cars before this).
Recently, an old buddy of mine, from high school mentioned that he had taken some pix of the car back then (around 1966). Here's a picture he scanned and sent to me not long ago. That's me at age 15, long before the grey hair came. We rarely cranked it with the handle since it was easier to get my friends to push it. We also used to put 2 batteries in series (24V) to get it going, but the electic starter eventually fried. Trafficators never worked but they looked cool.
Eventually, it snapped a rod. We pulled the broken bits out, and drove it for a while longer on 3 pistons. I have a few others he sent me:
Sherlock
Sherlock
Here's a picture of the Austin David (aka 78Z around here) sent me... (gotta get a digital camera sometime /ubbthreads/images/graemlins/rolleyes.gif) Actually, yesterday was only the second time I've ever seen a Devon in good shape, not counting some rusty wrecks I've seen
rovernut
James..........My 48 Rover has a starting handle and working trafficators which you looked at last year at Haugens /ubbthreads/images/graemlins/canpatriot.GIF /ubbthreads/images/graemlins/thumbsup.gif
Bill Robertson
Steve
Platinum
No experience wth trafficators, but until comparatively recently, Citroen were still including starting handles with all of their air-cooled cars, notably the GS/GSA, the 2CV and the Dyane. Great emergency backup, and I did actually use the thing once or twice. Love those Citroens!
Ken G
I am surprised that no-one has mentioned an important use of the starting handle, namely to turn the engine by small amounts while setting/checking ignition or valve timing. I cannot start my Rover using the handle (I'm not strong enough) but nonetheless I use the handle frequently. If you have no handle, you have to jack up a driving wheel, put the car in the highest gear, and turn the wheel (but this does have the advantage that you can turn the engine backwards as well as forwards!); that was the method I used on my Mini back in the 1960s.
Ken G, 1925 Rover 16/50 (San Francisco)
MGTF1250Dave
Aloha Sherlock,
As Ken pointed out, the starter handle is very helpful with many of maintenance checks. I had a failed starter motor and probably went about two years before I replaced it, during that time I used the hand crank to start the car. It always drew some curious looks and often questions.
If the ignition is working properly, about a one quick quarter turn will start the engine. My technique is to crank slowly a few turns with ignition off, this draws fuel into the cylinders. Crank around until you come up to a compression stroke (you will be able to feel the increased resistance), turn on the ignition and crank quickly. A safety note is that you should always use an cupped grip (fingers and thumb on the same side off the handle) in case the engine back fires. A back fire can jam the handle against your hand sharply, if the thumb is in the way it can be sprained or broken. A common aliment before electric starters.
Safety Fast,
Dave
Steve_S
Taken directly from my web site regarding my 1953 MG YB...
Upon leaving my sister's house late on Thanksgiving night, I found myself with a drained battery. I had stupidly left not only the keys in the ignition but the ignition itself on earlier in the day after showing off the trafficators. Fortunately I had a battery charger in the trunk and it really doesn't take much to start the car, so my sister, brother-in-law and I went out into the cold night to try charging the battery enough to get the car going. After several attempts the car still didn't have enough power to start as the battery was completely dead. Rather than mess with jumper cables, I decided to try and crank start the car which is something I had never done before on any vehicle. Fortunately I had recently seen a web site showing the proper way to crank a car - palms up. I turned on the ignition, inserted the crank and gave a pull, then a second. I pulled the choke out, then cranked a third time and the car came to life!
Crank still in hand, I raised my arms in victory. Quite unexpectedly I heard applause and cheering from a crowd of people down the street. I gave a wave and laughed as I cleaned up the charger and extention cords. Then, just as I was packing it all in the trunk, the car died. It may have had too much choke. No problem, I was excited to crank the car again anyway! I cranked it until I broke out in a sweat and just couldn't get it started this time. So swallowing my pride I decided jumper cables were the best way to go.
Of course the car started immediately so we put away the cables and moved the donor car. I said goodbye again and turned on the headlamp switch.
Nothing happened.
These cars don't charge until the engine has sufficient revs to get the generator going so I had no power to the lights. I decided I would simply drive the car and have faith the lights would remain on so long as I was at speed. So off I went in the dark, but as I hoped, the lights brightened with more engine speed and that's how I drove the 40 miles home.
Keoke
/ubbthreads/images/graemlins/savewave.gif
Say Ken, Did you know that you can simply put the car in gear and rock it!---Keoke /ubbthreads/images/graemlins/yesnod.gif
gjh2007
A starter handle?? My 1973 Land Rover Series 3 had one, Plus alot of other cool stuff like a PTO that came through the rear bumper to run all kinds of farm/industrial equipment.
I really miss that truck, except for the 10deg days in NE driving to work barley able to feel my fingers or see through the windshield!!
Sure was fun in the Summer though./ubbthreads/images/graemlins/cool.gif
heres a shot of her on the beach: https://home.comcast.net/~ghamilton99/wsb/html/view.cgi-photo.html--SiteID-1463097.html
Geo Hahn
[ QUOTE ]
...A safety note is that you should always use an cupped grip (fingers and thumb on the same side off the handle) in case the engine back fires. A back fire can jam the handle against your hand sharply, if the thumb is in the way it can be sprained or broken. A common aliment before electric starters...
[/ QUOTE ]
I usually do a couple of crank-starts at car shows for the benefit of the younger generation of car enthusiasts. Yes, I use the open-hand method -- though my engine doesn't seem prone to backfiring. I have heard that those who have engines that tend to back-fire use the thumb-wheel on the dizzy to retard the timing a few degrees to make it easier to start, then reset to running spec.
BTW - it is possible to crank start even if you have added an electric fan (on a TR3A anyway, probably on others too).
Ken G
Only on a perfectly flat smooth surface, and I didn't and don't have such a one! Besides, that wouldn't be practical single-handed with my Rover, weighing about 3700 lbs.
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
S TR2/3/3A TR3 Hard Starting Triumph 4
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G TR4/4A Starting without Transmission attached Triumph 9
P BN4 Hesitates on Starting Austin Healey 12
D Hard Starting Austin Healey 14
mgedit TR2/3/3A 56 TR3 Starting Issue Triumph 9
M Starting from cold Austin Healey 2
R Very Difficult cold weather starting problems! Austin Healey 21
R TR4/4A Starting TR4A after 30 years Triumph 12
R winter hard starting BJ7 Austin Healey 16
P Jump starting a positive ground BJ8 Austin Healey 4
W starting motor Jaguar 0
D TR2/3/3A Starting my Bodywork journey. Triumph 166
P TR6 Quick starting Triumph 2
Joe Reed General Tech Starting a screw in a tight location... MG 9
P TR6 TR6 hard starting Triumph 24
Q Just Starting Restoration Of 1967 E Type Jaguar OTS Jaguar 13
stretchit2 Starting Issue Austin Healey 6
M TR6 Intermittant starting problems Triumph 4
Willie_P TR4/4A Starting long dormant TR engine..start up procedures? Triumph 10
S Hard starting on Webers from cold Austin Healey 12
T TR4/4A Weird starting issue with my TR-4 Triumph 15
