dklawson
Some of you may remember that I am fitting a single rail gearbox to our '72 Spitfire project to replace its worn 3-rail box. I'm doing this with the help of my son so it's going to be a slow process.
I have ordered the new friction disk. I've also purchased the late model speedo cable and the shorter (38") driveshaft from a late model Spit to complete the transplant.
My son and I are ready to pull the gearbox and we (I) have a few questions before we proceed. It's been years since I did this with the GT6 so humor my probably obvious questions.
First, the gearbox is now only held on by a couple of bolts on the bellhousing and the rear transmission mounts. From memory... I believe I supported the back of the GT6 block with a floor jack so I could pull the gearbox up and back out into the passenger compartment. Is that whats' normally done with the Spit?
Second, the 41" driveshaft that came out of our '72 was the "strap-type". Each end had a round flange. The 38" driveshaft is the later type with a CV joint on one end. I've never seen these installed. One flange is rectangular, the other round. The bolt pattern on each flange is identical. So... which end of the CV joint type driveshaft goes where? Does the CV go towards the gearbox or the differential?
Third, there were two (reverse?) switches on the gearbox, both on the top cover... one in the back tucked under the shift extension, one on the front towards the bellhousing. Why are there two switches on the 3-rail gearbox when the single-rail box only has one?
Lastly, I was told I need to cut away a bit of the transmission tunnel in the tub to fit the single rail box. I know the single rail is roughly 3" longer and that I'll therefore need to cut out about 3" from the tunnel. Can anyone shed some light on this? Pictures or web links would be a great help.
Thanks.
Thanks.
