RJS
OK, had my speedometer rebuilt 10 years and 8,000 miles ago. Just recently, it stopped working. I replaced the cable yesterday and no luck. So, this afternoon I pulled the gauge out of the dash to inspect further. The input drive for the speedometer has a light coating of black looking grease which I expect is rather thick. Here's what happens when I spin it with a screw driver in the back:
Any ideas on what may be going on? Is it a mechanical failure which can only be repaired by opening it up? Is it gunked-up from oil traveling up the speedo cable? If so, will a drop of carb cleaner in the input drive loosen it or would that be a fatal mistake. Any other ideas?
If repair requires cracking the unit open, I will most likely send it off as I tend to be ham-fisted with delicate, sensitive components like this. Just hope they would charge me to clean it, not completely rebuild it.
Thanks
Bob
- Going CW it spins freely until about the 25th or 28th rotation and then I get some stiff rotations which I can gently turn past until it gets free again. Repeats every 25 to 28 rotations. Needle does not respond at all
- Going CCW it spins freely until about the 25th or 28th rotation and then it gets very stiff to the point I am afraid to try and push through it. Needle does respond as expected and I am 99% sure CCW is the correct direction of rotation.
Thanks
Bob
