TR6 Request for more advice on a TR-6 clutch replacement
chubahkah
? Any advice on how important it is to re-surface the flywheel when replacing the clutch? On a similar note, what about the pilot bearing located in the end of the crank, should it be repalced as a matter of course? - Thanks - Chubahkah
66 fhc
My experence has been you always do flywheel and piolet bearings along with the throwout bearing.Murphys law usually applies in these cases. You don't want to have to repull the trannie for relativly inexpensive stuff. While you're at it check the u-joints on the drive shaft. Nothing worse than pole vaulting down the freeway.
Administrator
Boss
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by 66 fhc:
<hr></blockquote>
I guess there are different schools of thought on this. Personally, I have never resurfaced a flywheel when chaning a clutch unless it was scored (like the clutch wore down to the rivets and scored it). I did resurface the one on my Spitfire once when I first did a rebuilt, but it had gouges dug into it as I recall. Definitely agree on the T/O bearing. Pilot bearings? probably not a bad idea unless you know for sure they are recent. Keep in mind, I'm cheap
66 fhc
It's always a judgment call. If it looks really good,the flywheel, like no gouges or discoloring from being overheated if the clutch was slipping for a long time and it's true with a straight edge across the face, I might skip it also.
Murphy
T
triumphant
As has been said already, just take a good look at it. If its not gouged or have any discolored "hot spots" (dark bluish areas), then it probably not necessary to resurface. It's not that it would hurt anything to do so, but why spend the money unless you know there's a problem? I would always, as a minimum however replace BOTH clutch pieces and the T/O bearing just as a matter of principal. You might also consider looking at the Clutch Master and Slave cylindars while you're at it...if they look good inside, at least put new rubber kits in them.
Cheers,
Larry
78 Spitfire!
J Request for soldering iron recommendation Restoration & Tools 6
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
Y MGB An odd (and probable long-shot) request... MG 5
A Hello from new member, and car identification help request Other British Cars 9
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
bfitz Vendor info request Restoration & Tools 10
Elva164 A New Race Video and a Request! Racing 3
SASSAMON TR2/3/3A Intro and Request For Help Triumph 5
L Request help with identifying this AH 1960 3000 part. Austin Healey 1
T Question on request for parts FORUM Navigation Questions 3
toysrrus TR2/3/3A HS6 Jet Assy Linkage Request Triumph 4
dklawson Sorry... Urgent Request for Friend - Marina Front Engine Plate Other British Cars 2
dklawson MGB Sorry... Urgent Request for Friend - Marina Front Engine Plate MG 3
D Spitfire Spitfire track width measurement request. Triumph 3
G `Request for Overdrive Speemometer Cable Routing Picture Triumph 0
RAC68 Request Battery Cable Length Austin Healey 3
PHerder Request for a part... Spridgets 7
A TR7 SU Conversion- Request to the MG Guys MG 4
mgedit Wedge Wedge Style Sidescreen ... Picture Request Triumph 8
T photo - odd request Triumph 5
T TR2/3/3A TR2 Sway bar questions/info request Triumph 5
Mowgli81 Back Seat Hinge Request Austin Healey 2
RickB My request to my family for Christmas Spridgets 7
B Midget 50th - The BIG Party Caravan request! Spridgets 0
T NLA SU HS6 part request Triumph 10
P GT6 Michigan request for help evaluating GT6 Triumph 6
P GT6 GT6 evaluation request Triumph 18
H Air Deflector Assembly Hardware Help Request Austin Healey 2
W TR2/3/3A TR3 Door Seal Rubber Question photo request Triumph 4
TR3driver TR2/3/3A TR2 history request Triumph 4
dklawson Spitfire Picture Request - Late Spitfire Hardtop Seals Triumph 3
theleisure Pix Request, "Oil Filter Switch" Spridgets 9
theleisure Tonneau Cover Photo Request Spridgets 1
J Clutch Fork Clearance Info Request Spridgets 2
Tim Tucker Vote Request Triumph 1
dklawson Dimension/Picture Request - RotoFlex Triumph 4
dklawson Spitfire Spitfire Steering Column - Picture Request Triumph 6
pan Request for help for Aussies in trouble in Italy Austin Healey 7
healeyboz another weird request Spridgets 1
healeyboz strange measurement request Spridgets 29
amcboy Mmmmm Carb Floats... And a request for opinions.. Triumph 10
M Part request Can anyone help? Spridgets 3
tosoutherncars Picture request - RB car, chrome rear bumper Spridgets 8
Shealey New parts hunting request. Spridgets 4
B Request help with a [BJ7] interior measurement Austin Healey 9
Brooklands TR2/3/3A TR3 Engine Suggestion Request Triumph 16
jlaird I have a request Spridgets 7
T A photo request Triumph 36
T E-mail request Triumph 2
T Reference check request Austin Healey 4
