Replacement Chrome Trim Rings For Instruments?
CCURTISS
My TR3 trim rings around all of the instrument gauges on my car are a little rough.
I see where Moss has replacement glass but I have not found a source for replacement chrome to go around the gauges, does anyone know of a source?
amcboy
Any current Smiths instrument dealer has them or can get them.
Nisonger Instruments in NY has them.
CCURTISS
CCURTISS
Thanks! There is good news and there is bad news with them. The good news is they have the rings for the small gauges.
The bad news is they do not have the large chrome rings any longer and there are no plans to re-produce them. I guess I am stuck with re-chroming the old ring unless there is another source.
TR4nut
I think you can still get them from the UK if you can't find them here - if so they are light so shipping should be reasonable.
For example, Holden might be a good possibility:
Holden gauge parts
Randy
amcboy
Drat!
I was going to buy a set of large rings for my new speedo and tach...
I guess I'll have to try elsewhere...
CCURTISS
CCURTISS
FYI, I checked with Holden and they said they could not help me on the large rings. I will have to keep looking.
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
WHT Rocker Arm Shaft Replacement Austin Healey 21
Celtic 77 MGB Seat webbing replacement. MG 1
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Celtic 77 MGB Seat Diaphragm replacement MG 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
K TR2/3/3A Wing mirror replacement again... Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
B T-Series Battery replacement mgtd MG 2
F TR4/4A Speedometer cable replacement access Triumph 0
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
T TR2/3/3A Replacement radiators Triumph 8
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
F TR4/4A Replacement air filter for SU HS6 Triumph 6
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
A MGB MGB 1974 windscreen centre rod replacement MG 5
B Poor quality BE replacement spring boxes Spridgets 0
AUSMHLY BJ8 Laygear Replacement Options Austin Healey 0
B TR6 Fuel tank replacement Triumph 0
S MGB clutch replacement MG 7
S Wiring Harness Replacement Spridgets 1
JPSmit Not something you see everyday - a warranty replacement Spridgets 1
M 1972 Midget Seat Belt Replacement Spridgets 4
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
T TR2/3/3A tr3 front carpet replacement Triumph 5
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
D Engine replacement. Rover / Land Rover 0
EWD TR6 Dash Pad Replacement Triumph 3
R TR6 fan shroud replacement Triumph 5
C Replacement wheels Rover / Land Rover 1
B TR4/4A Floor pan replacement Triumph 4
DrEntropy MGB Replacement starter MG 7
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
P TR6 1970 TR6 Passenger Sun Visor Replacement Triumph 1
M General MG Midget MK1 windshield replacement MG 2
M TR6 Replacement Steering Rack ? Triumph 7
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
A TR2/3/3A TR3-A replacement top Triumph 7
C TR2/3/3A Horn Control replacement Triumph 3
nichola TR6 Transmission front seal replacement question Triumph 8
J BN2 Shift Lever Bushing Replacement Austin Healey 6
L 100/6 replacement front seats Austin Healey 7
B For Sale rat-co.com Replacement Frames for all TR models Triumph Classifieds 0
A Front Shocks Bushing Replacement Austin Healey 2
