Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
[/ QUOTE ]
The Moss picture shows item 15 for the front and back; 6 required. The front and back are actually slightly different. The back side of the agjuster are acually different lengths, the (4) for the front are 3/8" long and the (2) in the rear are 1/2" long. I sent some to Jack a while back but I'll look to see if I have any others. I assume you need the back ones from the thread title.
By the way, are you converting to disks up front with the extra power?
I have a whole rear end still in the car that will be disposed of. I am sure that I have what you want. Tomorrow I will jack it up and pull the part. send me your address. beedle@verizon.net
Every part is worth something to someone. Break it down if you can and stash it away.
Another item that is no longer made. The alum clamp that holds the stearing shaft on at the firewall, as well as the plastic peice between the steering wheel and the dashboard.
If there is any serious question in your mind as what to save and what no ask. Think I got it figured out preaty much.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
