Nice work, Paul. Just a few observations (NOT criticisms):
1. Maybe I've been lucky, but I've always been able to free these up with no more than a propane torch, after which some time with the wire wheel, etc., gets the bits pretty clean. On reassembly, I've long used white lithium grease, mostly because I've been nursing a can of Lubriplate for almost 40 years now (it's finally about spent), and it's worked quite well. It does make sense to use a good anti-seize compound, though, and I'll probably try that next time. I will note that, in nearly 40 years of wrenching on these, I've never yet failed to rescue and restore an otherwise undamaged adjuster!
2. My memory tells me that these usually were retained with star washers under the nuts rather than lock washers, but then 98% of my experience is with the Heralds, Spitfires and such (although it's the same adjuster used on later TR3 through TR6). Did all yours have lock ("spring") washers originally?
3. From your previous experience with "repro" adjusters, I'm glad that I've been stubborn (frugal? outright stingy?) about cleaning my originals up as needed! :wink:
