Protecting bonnet from rocks
dcoplan
Member
Wondering if any of you do anything to prevent rocks from chipping the front of the bonnet. A bumper is an option but I really like the look of the car without one. Is there some sort of protective transparent film that can be put over it that won't harm the paint if/when pulled or a driving bra?
Dan
There is a clear vinyl sold just for this purpose. However, I prefer to ignore the chips and drive on. My life is too short to worry about rock chips ... I'm here to have fun. :smile:
JodyFKerr
AN5Sprite
I wouldn't risk tempting fate. Put the vinyl on to protect against pebbles - get backed into by a Suburban. :tongue:
RickB
My rattle can paint, although it was advertised on the cans as being "automotive paint" has chipped very badly.
On the one hand it was cheap.
On the other hand my bonnet is flecked with a lot of little spots from rocks.
When I paint it again I'll use my compressor and HVLP gun.
Does a place like Eastwood have a paint I can shoot that will be a little tougher (or a lot tougher would be nice)?
Summit racing has good prices on decent paint if you want a "stock" color. Otherwise, try some autobody supply shop that has mixing systems from something other than the "big names". here is an example of such a manufacturer: https://www.matrixsystem.com/
bug_sixty
when your car is lower than a 18 wheelers tire..**** happens... drive it as it was meant to be... pos... when desired undo eight bolts and pull bonnet and a quick sand and paint job...
Nelson
I have heard that, for short time useage, the plastic film that realtors use to cover carpets for open houses can be used.
Jim_Gruber
Another reason for DIY Methodology rather than a $2,500 paint job. Rolled on Rustoleum works well, easy to fix. Someone here did Interlux Bright Sides Boat paint. Designed to be rolled or sprayed. Flattens well, provides good gloss and recommendation is not to sand or buff. I did paint a sailboat I raced using what was described as Corvette Paint, Deltron or something starting with a D. really, really hard paint. Could run into other boats and not leave a scratch. Drawback temperature sensitive when applying in Spring. I needed to paint outside, used cold temp additives in paint but one side of boat was in sun when painted but before it cured, that side moved into shade and temps dropped. Came back next day to discover major sags and runs on the bow area above the water line. Paint was almost impossible to sand down once cured. Not sure if still made as paint was known carcinogen I found out later but it was tough paint.
nomad
There's always bra's! Remember them?! I've seen a bugeye with one. I suppose they had a proper name but we always called them "bra's". If the front is covered with naugahyde and padding you won't get chip's. Paint chaffing under the covering but no chip's!
Kurt.
JPSmit
Kurt.
Proper name is Car Bra - Had a car once with one - the slight wind buffeting was not kind to the paint underneath.
J Protecting new wiring harness under car section-Use clear shrink tubing? Austin Healey 4
74WannaB protecting metal during restoration Restoration & Tools 9
R Protecting Aluminum Body Trim Austin Healey 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
CARSINC Sprite bonnet emblems Spridgets 4
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
E TR6 TR6 flip-up bonnet question Triumph 4
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
Bayless Help please installing bonnet release cable Spridgets 8
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
LAW75 Bonnet Excessive Sway Austin Healey 6
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
K TR2/3/3A The Louvered Bonnet? Triumph 2
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
J Wanted Austin Healey Sprite Bonnet Austin Healey Classifieds 4
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
mch979 1967 MGB GT bonnet issue MG 25
P MG TD Bonnet Upper Sections MG Classifieds 0
longbridgehealey Bonnet stay Spridgets 3
J Bonnet rubbing Spridgets 12
S Forward opening hood / bonnet Spridgets 10
R Mark III Bonnet Badge Austin Healey 9
F TR2/3/3A Bonnet safety hook Triumph 10
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
B Bonnet hinge gasket Spridgets 10
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
GeorgetheTR3 TR2/3/3A Bonnet popper, or something like that. Triumph 5
B Under bonnet fuel Austin Healey 15
charleyf TR2/3/3A Bonnet safety catch Triumph 0
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
4tecdog Fibreglass bonnet washer fittings Spridgets 5
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
T Bruce Uchida Front Tilting Bonnet, 2008 Spridgets 10
Lin Bonnet Striker Pin Assembly Austin Healey 5
R bonnet hinge R or L Austin Healey 2
longbridgehealey Bonnet belt Austin Healey 16
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Bonnet Latch/Release Adjustment Austin Healey 3
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
fmichaels Bonnet hinge holes Spridgets 4
Rhodyspit75 Bonnet gas struts Spridgets 5
L TR2/3/3A Hood / bonnet plinths Triumph 12
C Under boot and under bonnet paint? Austin Healey 7
D TR2/3/3A bonnet safety catch Triumph 4
N For Sale 1971 to 1980 Triumph Spitfire Bonnet Triumph Classifieds 0
Rhodyspit75 Bugeye bonnet prop rod Spridgets 2
W Electrics, fuel system, under bonnet temp. Austin Healey 3
