Progress-new thread Monday
I know there's a gasket for the rear oil seal housing - its a "U" shaped thing - that goes between the block & the seal housing itself.
Hi Tony, What I had in mind for Jack was a component for his engine Like the "Rear Seal Conversion " kit Moss Part # 833-415 Used on the Big Healey engines they work a treat.---Keoke
Here is another thought if the usual suspects do not have one for these smaller engines. Mini Mania may be a source for one--Keoke-???
I'll look in my Mini Mania catalog
Bugeye58 said:
They've been somewhat less successful on the "A" Series engines.
Jeff
Hi Jeff, this may be due to sloppy installation some people have problems with them on the Healey too. Because the rear main cap and the block are not properly aligned, or they fail to hook the seal spring correctly.--Keoke--??
My experience has been with two very experienced and highly respected professional engine builders. I doubt faulty installation was the problem.
Jeff
Yep, I have seen them fellas goof up too.--Keoke-- /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
It wasn't just one isolated incident. In the case of one builder, I worked with him for nearly three weeks, on more than one engine, trying to get some of the rear seal kits to work. It just wasn't going to happen.
Jeff
I see that Mini Mania has a rear seal at 1 1/4 inch and 2 inch. I assume a 948 Bugeye is 1 1/4 is that correct?
I looked at the pic but do not see how that thing gets around the crank, you sure can't slip it on the end, it has to be in two half moons?
Well of course that casn happen if you only have a single kit available. In the Big Healey case there are more than three or four designs, one of which initially had a bug in it and no matter who installed it, it would leak. The others all seem to work fine.---Keoke
<span style="color: #FF0000">Anyone see a source a bit less restrictive to the pocket book MM wants like $249.</span>
Does anyone know how oil that gets past the flange on the flywheel is supose to get back into the crank or is it not.
I see that Mini Mania has a rear seal at 1 1/4 inch and 2 inch. <span style="color: #FF6666">I assume a 948 Bugeye is 1 1/4 is that correct?</span>
I looked at the pic but do not see how that thing gets around the crank, you sure can't slip it on the end, it has to be in two half moons? <span style="color: #FF6666">Anyone see a better pic anywhere?</span>
<span style="color: #FF6666">Anyone have a end cap to look at?</span>
I put that darn thing in, the eyebrow peice and know I did it correctly. I also know the tolarance is real real tight. No way to get a feeler in there but it is so close it looks like it is touching even. I even used a straight edge on the eyebrow to make sure it was not warped or something.
I did note however that there was no way to adjust the lower scroll seal as it is part of the rear bearing cap and what you see is what you get. But from what I could see it was a real real close fit to the crank.
Shaired the leak with wife, she said well pull it again till you get it right. I am inclined to agree with her, however untill I know what to do that I have not done it seems a bit senceless.
Well Jack, that is a bit pricey. However the price probably reflects the dollar's demise on the market. Maybe Tony can shave a dime or two off. OTOH, if the tolerances of the seal are as tight as you say then the seal will only leak a small bit. It's design is such that when it quits pumping, engine off, the purposely long scrolls will retain an amount of oil that can simply run out the back end. If this is now your case I wouldn't be too concerned over the leak.
Please note: if the seal lip does not leak to lubricate its self it will wear the shaft and become a big leaker later on.
I Missed it initially some one put the MM webpage up on this forum. The seal is quite a complex piece of hardware and this may account for its cost.
Really guys, I'm sure someone told me that Paul (morriservice) has a solution.
Hi TJ, you certainly would think so as this has been an on going problem with the British engines from the git go.--Keoke
If I leave it at idle like adjusting the carbs for five min or so I will get a plate size splotch on the floor.
I really don't have a big deal about removeing the engine again, forth time, I'm getting quite good at it. But would like a real solution before I do so.
All my Bugeyes have leaked but not that much.
Jack,
I went thru nearly the exact scenario when I built my 1275. I too removed the engine 3 times and each time I only found oil coming from the scroll seal area. I know this may sound crazy, but I think I read in one of your threads that you had a vent hose connected to the valve cover and a somewhere else. The 1275 valve cover should only have a small orifice not a large tube like the 948. My oil leak stopped nearly completely when I ran a hose from the intake manifold directly to the front cover with a PCV valve in it. The valve cover has nothing attached to it and no other hoses. The 1275 must vent from the front and it needs a lot of negative pressure. I think you should try this before you take the engine out again. You have strong oil pressure and new rings. I think you have a ventilation problem. I would bet that the seal kits do not work well on 1275 because of the crankcase pressure. I have 70 psi cold and 45 hot with only a drop or two of oil leaking. Before, I was getting a huge puddle and a drip about once per second at idle. That's just my opinion on what worked for me.I wrote all of this on some earlier threads back in the spring when I first joined the forum and on SpriteSpot also.
Hey Jack
Let's go a little slower this time. Now let's all just think about this. What type of oil do you have in it?
What oil pressures? Cold Hot
Mark
20-50 Castrol.
Cold 60 upon start.
Operating temp. 20 idle, 40 2500 RPM, have not gone over that, fresh engine.
Oil pressure is great, finaly got that sorted.
This is a 948 engine, so has vents on valve cover and chest cover both are big and open. When I am messing tomorrow I will check and see what kind of pressures I have from those tubes but no oil is comming from them.
Let's see how much compression you have?
The other thing is let the car idle and take the oil filler
cap off. See if the idle increases it should not.
Mark
