<span style="color: #FF0000">Anyone see a source a bit less restrictive to the pocket book MM wants like $249.</span>
Does anyone know how oil that gets past the flange on the flywheel is supose to get back into the crank or is it not.
I see that Mini Mania has a rear seal at 1 1/4 inch and 2 inch. <span style="color: #FF6666">I assume a 948 Bugeye is 1 1/4 is that correct?</span>
I looked at the pic but do not see how that thing gets around the crank, you sure can't slip it on the end, it has to be in two half moons? <span style="color: #FF6666">Anyone see a better pic anywhere?</span>
<span style="color: #FF6666">Anyone have a end cap to look at?</span>
I put that darn thing in, the eyebrow peice and know I did it correctly. I also know the tolarance is real real tight. No way to get a feeler in there but it is so close it looks like it is touching even. I even used a straight edge on the eyebrow to make sure it was not warped or something.
I did note however that there was no way to adjust the lower scroll seal as it is part of the rear bearing cap and what you see is what you get. But from what I could see it was a real real close fit to the crank.
Shaired the leak with wife, she said well pull it again till you get it right. I am inclined to agree with her, however untill I know what to do that I have not done it seems a bit senceless.
