As I was cleaning up after my front end rebuild and I reread the instructions that came with my Polythane bushings. The Polythane bushing kit for the A-arms did not have metal bushing inserts in them but the regular rubber bushings that came with the kit did.
Was I supposed to cut out the metal inserts in the rubber bushings and press into the poly bushings? Seems like to should have but what confuses me that the kit that I bought for the rear springs has them already pressed in the poly bushings, at least for the foward most attach point on the rear leaf. If they were meant for the A-arms, I don't undestand why they wouldn't come that way when the others did.
If I should have used the metal bushing inserts, what would happen if I didn't tear everything back down again but kept it as it is? I am sure it would wear earlier but I dont drive the car that often. I just dont want it to be dangerous.
