Plastic fans
TR4eh
I have a yellow plastic 8 blade fan but I see that some (but not all) of the usual sources now offer a blue plastic fan. Does anyone know if the two fans are the same? For aesthetic reasons I'd rather have the blue one.
TIA,
Cliff
CTC64615L (being reassembled)
DanB
I think the original fan was a 4 bladed aluminum fan. At least that's what was on my car when I got it in 1980. Mine has an 8 bladed yellow plastic fan from a TR6 that I put on there to move more air. I have never seen a blue one. I have seen red and white as well as the yellow. So if you are asking for originality, you are probably not original anyway with a plastic fan on a 4A.
Dan B
PeterK
There's always plastic paint. Much le$$ than a new fan and it holds up really well.
Geo Hahn
Hah -- I just got it... "TR4eh".
Since the blue flavor may be a fairly recent development you may need to ask a vendor if they are the same as the usual yellow variety.
As noted, plastic paint works well. I used a black-painted yellow fan for awhile until I found a correct (albeit optional) tropical fan.
Moving more air is good.
T
TR4eh
Plastic paint - why didn't I think of that :smile: Car is now Royal Blue, black engine, the yellow fan is just not working for me.
Thanks muchly.
HerronScott
Welcome by the way and always glad to see another Royal Blue TR4A around (my favorite color on that car and yes I'm biased!).
Scott
PeterK
Keep looking. I found one on ebay but they're never inexpensive, usually over $100 unrestored.
jsfbond
Thanks muchly.
Sem Color Coat Aerosol # 15643 is a Pacific Blue for plastics and also used for carpet color changes. Great stuff, make sure to clean the surface very well.
PeterK
There is also A SEM pre-paint for plastics. More of a cleaner/conditioner, not a primer per se.
croz
Hello TR4eh,
Last year I ordered and received a blue plastic TR6 fan that I am using on my TR3A - with and adapter from Rimmer Bros.
Check the link below.
https://www.rimmerbros.co.uk/Item--i-308353
During my rebuild I salvaged a white plastic 6 blade fan from one of the donor TR3's. Each of the blades is fastened to the hub by 3 rivets. Does anyone know the origin of this fan?
jsfbond
SEM 38354 Plastic & Leather prep (Prepares plastic and leather substrates for painting)
SEM 39133 Flexible Primer Surfacer-aerosol(provides superior adhesion, sealing properties, film build, and flexibility when coating automotive plastics)
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR6 Frosted rear plastic window Triumph 6
AUSMHLY HD8 damper with Brass or plastic cap? Austin Healey 8
M E-type series 1 plastic dash vents Jaguar 1
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
NutmegCT Chrome plastic? Restoration & Tools 11
7 stupid plastic cooling system parts Other Cars 2
R How i restored the plastic and rubber trim on my car Restoration & Tools 3
gbtr6 TR6 Need a plastic dash light plinth Triumph 17
Steve P. six blade plastic fan bolts? Spridgets 6
maxwedge5281 refinish trafficator plastic? Austin Healey 20
KVH General Tech Timing and Valve Tuning--with a plastic fan Triumph 4
J TR6 Starter front plastic cap needed Triumph 4
D Plastic Paint??? Spridgets 9
BoyRacer Top bows - plastic sleeve for socket Austin Healey 0
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
60TR3A Should My '63 BJ7's Carburetors Have Brass Caps or Black Plastic? Austin Healey 3
mdionne MIDGET Badge Plastic Inserts and Decals Spridgets 2
D How do I clear up a plastic rear hard top window? Restoration & Tools 3
bthompson Plastic fill plugs?! Spridgets 1
PAUL161 Meguiars Plastic cleaner Question MG 2
S cleaning old plastic Triumph 6
V TR6 Top, aftermarket plastic/fiberglass for TR6? Triumph 6
ShawnC_at_Moss MGA New - Plastic Fan for MGA & MGB to 1971 MG 10
AngliaGT Plastic Radiator Leak Other Cars 1
T Source for plastic picks / pointed tool? Triumph 31
AngliaGT DM - Lotus Elan S2 Plastic Model Lotus 1
bcbennett TR6 TR6 top cover/plastic snaps Triumph 5
af3683 Cleaning Convertible Top Plastic Windows Triumph 4
T TR4/4A TR4A plastic fan options Triumph 14
Jer plastic cooling fan options for 1275 Spridgets 4
John_Nichols Triumph Surrey Top Window Plastic Reproduction Triumph 3
Hedgehog Plastic conv window foggy Restoration & Tools 3
dklawson Metal vs Plastic Facet Pumps ? Spridgets 2
A Painting plastic [interior] Restoration & Tools 9
Y Plastic Battery boxes Triumph 0
mountainman TR 3 with Plastic Surgery Survey Triumph 13
T Plastic cooling fan for BE - fit question Spridgets 5
S cleaning Bakelite or plastic Triumph 3
CinneaghTR TR4/4A TR4 Plastic Battery Box Liner? Triumph 4
Gundy Brittle plastic..the good n' the bad Other Cars 7
SherpaPilot Slave Cylinder Plastic Pipe Alternative? Triumph 15
Z AH BN1 Plastic VIN Plate Austin Healey 10
Yngbld14 plastic window repair Spridgets 10
RickB Cleaning of plastic windows - just tried McGuire's Spridgets 5
Stewart Moss plastic fan shroud MG 2
G Plastic intake manifolds Triumph 3
M Restoring Plastic Triumph 11
Basil Restoring plastic lens covers? Restoration & Tools 6
JPSmit cleaning plastic - any ideas Spridgets 6
