I took apart my 1979 front seats. Removed all of the upholstery for a complete remake using MOSS's kits, foam, etc. However, when the seat was removed, there was a 3 prong wire hangin out of the bottom of it. As I removed the vinyl, I founs a plastic disk about 5-6 inches wide attached to that wire. It had a wire coming out of it (it was detached from the car somewhere...?) and the disk was a kind of switch. If you push it, it pushes in (clicks). Any idea what this is?? I think it may have been hooked up for the seatbelt warning light or something? The foam was molded for it and it had a thin metal bottom where it was glued to the foam. If anyone know what it is please help me find replacements! I only did the drivers side so far> not sure if the passenger side has it or not. Thanks!
