David64MGB
Member
How much wear is acceptable on the oil pump spindle? The involute splines on mine are worn by about .010" to .020" as visible at the crests. Wear varies from tooth to tooth.
Should I replace it? I haven't looked at the mating gear on the camshaft yet. The distributor drive spindle shows much less wear, but it may be newer.
I have attached a picture. Am I just being paranoid?
Thanks,
Thanks,
