Famous last words. :wink:[/COLOR]
Thanks - knew you'd be there for me... :smirk:
The driveshaft situation has me puzzled. I didn't run into that with either of my two Victors. Both of them had the longer water pumps, and still had fan/radiator clearance. Sounds like you have gotten the situation solved.
Once you get the body and fenders mounted, you will find that the real work starts, with wiring, hydraulics etc. fitting the interior is fun too. Are you using MGB seats, TF seats, or something else? One of mine ( a kit car)used MGB seats, the other had the TF seat copies that came in the car(factory finished car).
Sounds like you are enjoying the car, keep us posted on progress.
Cheers.
Bruce Clifford
Now you are *talking*! That bundle of wires would completely overwhelm me.
(What's the red color on the underside of the frame?)
No idea - maybe a reflection from something under the lift.
Mickey - is it possible that the entire body (and the mounted dash panel) slightly changes shape when the heavy stuff (engine ...) is put in place?
Might be what's causing your fitting headaches.
Tom M.
