M
Mike
About every 10 miles or so at low idle I go into a sputter that will stall unless I rev up. Only sputters at low idle not at higher rpm. After several revs (30 seconds or so) everything returns to normal. The carbs have plenty of gas in the the bowls so I would assume this is not a fuel line issue. Took it by a mechanic and he didn't think I was losing spark. I wondering if I need to rebuild the carbs or is it a intermittent short that occurs at low rpm and the short is stopped by higher revs. Any suggestions.
Thanks,
Mike
1958 Bugeye
Thanks,
Mike
1958 Bugeye
