TR5/TR250 NAPA U joints fro TR250/6
gjh2007
Has anyone had any experience with the NAPA ujoint 220-1100 on their TR?
They have them in stock & it is handier than waiting for the shipping.
They also offer a "performance" model that is $5 cheaper. Go figure?
I've always had good luck with NAPA products.
TR6oldtimer
I believe you should have no problem with Napa parts. That said, you get the heavy duty u-joint. The beefier u-joint will have a larger diameter trunnion and a thicker cross member then lighter duty u-joints.
G
gjh2007
He told me they were made by precision.
T TR2/3/3A bad napa points Triumph 9
T TR2/3/3A Napa dot5 ok Triumph 4
C NAPA master cylinder rebuild kits Spridgets 19
tahoe healey oil sale at NAPA Austin Healey 4
glemon NAPA or other Parts Numbers for Triumph Parts Triumph 9
apbos TVR in NAPA Ca TVR 3
Newkie Napa Gold oil filter MG 5
C Castrol on sale at NAPA Austin Healey 2
A NAPA Radiator Hose Equivelent Austin Healey 11
AUSMHLY Oil filter, K&N vs. Napa Austin Healey 2
Gray_Cat Bugeye For Sale in San Diego [and Napa] County Spridgets 4
J TR4/4A TR3, TR4 bypass hose needed , NAPA #? Triumph 2
D TR4/4A TR4 inner ball joints Triumph 8
OZ_BN1 Drive Shaft Universal Joints Austin Healey 2
Hamish Racing TR2/3/3A Sway bar rose joints and diy brackets Triumph 4
Bugeyze Universal joints Spridgets 6
R Moss permanently lubricated U-Joints Austin Healey 1
B TR2/3/3A Anyone have quality problems with TRF's TR2-4 ball joints? Triumph 10
D TR6 U-joints Triumph 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
AngliaGT TR6 TR6 U Joints Triumph 3
Foura TR4/4A Steering column Universal Joints Triumph 10
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
RickB Crimped in U-joints? Spridgets 7
6TTR3A TR6 Replacing the IRS u-joints on a TR6 Triumph 15
vette Throttle Linkage Ball Joints Austin Healey 5
V Upper Ball Joints Triumph 16
sd80mac7204 Universal Joints Triumph 3
RJS Greasing U-joints Triumph 13
Willie_P TR4/4A restoration - ball joints, TR4 Triumph 10
5 Steering Ball-Joints Austin Healey 3
mikecyc72usa Oh the fun of U-joints Triumph 19
SkinnedKnuckles TR6 TR6 Ball Joints Triumph 13
M Broken Ball Joints Spridgets 14
B TR6 TR-6 U-Joints/Half-shafts Triumph 13
King_of_England Ball Joints and Mini ID British Motor Corp 7
T TR4/4A tr4 steering column-replace rubber with u-joints? Triumph 9
Popeye Welding butt joints... crack in weld after grindin Restoration & Tools 3
Tabcon Ball Joints and mushy rubber Triumph 7
Z Dive Shaft Uni Joints Austin Healey 10
I TR6 How do I grease TR6 trailing arm u-joints? Triumph 8
Dadandson My U Joints are clicking away Spridgets 14
bigjones Ball Joints - does this look right to you? Spridgets 12
mrv8q TR6 TR6 carb "ball joints" Triumph 10
N grease for rear axle sliding joints Triumph 14
svtmikey Un-joints - I don't remember them being this hard! Triumph 29
L Tightening U-joints Restoration & Tools 3
dklawson TR6 U-Joints Comparison, TR4 vs. TR6 Triumph 3
D TR4/4A tr4 steering - inner ball joints loose Triumph 14
A TR6 Jag ball joints donot work on TR6!! Triumph 5
