Missing hood prop problem.
bev1957
We are missing the hood prop (which, of course, it looks like we may definitely need). We have a new prop to install (the expanding-sliding rod type from Victoria parts), there is a bolt on undersurface of the hood, but no apparent mounting site on the engine fender. Is there another mounting piece we are missing? I owned a 1979 mg midget 'cheetah' 20+years ago, but I cant remember how the hood prop was installed.
tony barnhill
Great Pumpkin - R.I.P
Shouold be a small bracket on edge of fender....now, what's a Midget 'chetah'?
B
bev1957
Tony,
Of course, our midget is missing the bracket on the fender. So, we'll figure something out. My first midget was the 'Cheetah', which I bought new in 1979. It was white /c black interior and had a red/black dual stripe along the lower portion of sides which terminated in the word 'Cheetah', with a sillouette of a cheetah running. My then husband promptly sold the car after we married in 1981 to a man in St. Petersburg, and that is the last time I've ever seen a midget with that type paint/stripe detail.
tony barnhill
No such animal! All that 'cheetah' stuff was jusr dealer installed items so he could get rid of his lingering stock as the company went belly up! Most dealers dolled up their last few cars & called them something to get rid of their stock!
Bugeye58
Isn't "Cheetah" the way they pronounce "Cheater" down there?
Jeff
tony barnhill
Only around Savannah or N'Awlins!
B
bev1957
Okay, okay, so maybe I fell for the dealer gimmick. At any rate, it was a great looking car (dealer striping and all), and, as I said I havent seen one with quite the same panache since. By the way, we don't all have such a southern drawl. Do you think the mounting foot for the bugeye would work to install the hood support on the midget?
tony barnhill
On some cars, they're pop riveted, on others, bolted...I've several Midget parts cars...email me off-bbs
B
bev1957
Bugeye58
Bev, that was just the Dam' Yankee coming out in me! When I was in the Air Force, and stationed in middle Georgia, everyone up here thought I had a southern accent. Of course, I probably did, for survival purposes, if nothing else.
Jeff
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
K Missing spring clutch release lever Other British Classifieds 1
Rob Glasgow Missing Graphite Electrode Austin Healey 16
Bayless Missing important part Spridgets 0
bighealeysource Wanted Looking for missing BN2 door and cockpit moldings Austin Healey Classifieds 0
Jim_Gruber Missing Bugsy IV / Transporting a BE on a U-Haul Car Carrier Spridgets 18
warwick-steve Missing grease cap in front hub Austin Healey 8
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
T TR2/3/3A Missing bush Triumph 4
G Brake fluid missing Austin Healey 6
R brake master missing seal Austin Healey 11
P TR2/3/3A Missing rear seat back rest/bulkhead. Triumph 7
KVH TR4/4A I Can't Stop Burning Oil; Engine Missing at Take Off Triumph 5
Simmo MGA Missing under load MG 3
B Valve Cover Plate Rivets: Useless junk or am I missing something? Austin Healey 10
S TR4/4A Exhaust manifold missing stud Triumph 8
P Is my shifter bushing missing? Austin Healey 25
J Help with 61 AH Sprite missing parts. Spridgets 3
GTP1960 TR2/3/3A hesitation and missing between 2000 & 3000 rpm Triumph 3
tomshobby Shift knob insert is missing Spridgets 12
KVH TR4/4A Still Learning: I'm Missing, But Only Slightly Triumph 4
richie TR4/4A Missing since rebuild with Pertronix Triumph 9
B Installing New Leaf Springs on 100-6 - Am I missing something obvious? Austin Healey 19
bighealeysource Why is it missing now ? Austin Healey 4
RedTR3 TR2/3/3A Periods of Intermittent Missing Triumph 34
6TTR3A TR2/3/3A MIssing Zerk fitting? Triumph 7
bighealeysource Can't figure out why engine is missing on BN2 Austin Healey 6
J MGB MGB missing and perhaps knocking under load MG 10
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
Boggsy64 MGB King Pins appear fine am I missing something? MG 3
PHerder Door Parts missing :[ Need to beg, buy or steal... Spridgets 0
PAUL161 MGB Strange Reminder of a Missing Friend. MG 4
Parker MGB Headlights won't work after full repaint/restoration... what am I missing? MG 6
S MGB Radiator cap missing MG 1
P New tires, missing spoke Triumph 4
bighealeysource BN2 still missing, think it's carbs not ignition ? Austin Healey 8
mgbmedic Wire Wheel Conversion - What am I Missing? Triumph 11
S TR2/3/3A missing problem with this tr3 Triumph 10
bighealeysource BN2 missing on acceleration Austin Healey 11
H Missing Oil Filter Spring Plate Austin Healey 2
M Missing zerks Triumph 10
judow Is a Registry missing??? Austin Healey 12
jsfbond Missing Plate Triumph 1
E How to identify Healey carbs, Tag missing Austin Healey 1
P Missing grille bar Triumph 3
M Missing at the Olympics Triumph 3
RAC68 The Missing Brake Fluid Mystery Depends Austin Healey 11
F Missing and hesitation, only after a hot start Austin Healey 6
